20 Most Recent
Canon LASER SHOT LBP-3000 Printer Questions & Answers
Print legal size paper problem
when you give print command that time chage the paper size from a4 to legal in print proeprties and choose paper size legal.
Canon LASER SHOT LBP-1210 Printer how to set legal
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word
documents and befor printing you need to set in printer properties
"Legal 1′ for printing. Print preview may not show the whole page but
the printer will print the whole page.
All the best.
HOW TO RESET PRINTER CANON
hi it is different between driver and reset!!!!
all post about driver but question about reset software pls put a useful link
PAPER JAMMED IN CANON LBP
I think it is rolled with the fixing unit along with the teflan sheet.Remove the back cover and gently try to remove it otherwise remove the fixing unit and remove the paper. It it occurs oftem please change the fixing unit.
How to print without dark smudge on right side?
You can try doing maintenance on the machine with the included software that you installed when you bought your printer. Cleaning out the nozzles as well as the paper feed through the options provided should solve this problem. Hope that helps.
