20 Most Recent
Thermador PRG364GLUS Gas Kitchen Range Questions & Answers
How do i gain access
go youtube you will see spark module in short video undo two burners in left side of range
5/13/2014 2:29:09 AM •
Thermador...
Answered
on May 13, 2014
How do I put the oven door back on, it was
We did fix our problem the the Thermadore. Someone accidentally pulled the door off trying to pull it out from the wall during a remodel at our church. We couldn't figure out how to get it back on but i found the info i was needing. It is now fixed but thank you for your time..
1/11/2010 7:46:57 AM •
Thermador...
Answered
on Jan 11, 2010
The bottom heating element is not working on my thermador prgs/36
one of 3 things may of happed. 1, the element may have burned out. (you will see a blister or burn through on surface of element. 2 the wires that go to the element may have burned off. 3 the power relay board is not sending power to the element. (bad board or fans sail switch NG)All things need to be checked with 220v power off to the range. I would recomend calling a local pro.
10/30/2009 3:45:54 AM •
Thermador...
Answered
on Oct 30, 2009
Replacing the TRD sensor in a Thermador double oven.
Please look on page 40 of the manual for the Thermador SMW272 B Service Manual to find specific directions for removing the sensor. You can text "SUPPORT" to 53730 for quick access to such documents or call 1 (800) 735-4328 to speak to Thermador.
Thank you.
2/24/2023 1:20:05 AM •
Thermador...
Answered
on Feb 24, 2023
Thermador model GGCV30 gas cooktop
The flame spreader in the middle of the hob has a small hole that directs as jet of gas to the igniter. Put it in a pan of water and dish soap and gently heat it to almost a simmer. Be careful, it will want to boil over. Leave it to cool and and rinse it well paying attention to the holes in the edge. Blow it dry and try again.
10/26/2021 11:12:20 PM •
Thermador...
Answered
on Oct 26, 2021
How to change the switch on a thermador UCV36
www.
thermador.com/support
ThermadorThermador customer support is your appliance resource for FAQs, use & care videos, product registration, warranty information, service, repair and more.
www.
thermador.com/faq/categories.php?categoryid=63
ThermadorWe recommend that a Thermador authorized servicer change the seal ... refrigeration appliances, especially when the cooling function is switching on or off.
www.shopyourway.com > Manage My Life > Questions
Get shopping advice from experts, friends and the community! I have a Thermadordowndraft vent model number RDDS30VRS that I need to replace switch part ...
8/31/2021 9:18:11 PM •
Thermador...
Answered
on Aug 31, 2021
I have a Thermador PRSE304SLP
4 burner stove. The front burner on the left will not ignite. It does have spark. All the little holes are clear in the cap/cover.Everything is dry. It’s been like this for quite a while. It does not click like the other three when i push in and turn it and does not get gas. Is this a bad gas solenoid ?
you hear clicking and see sparks as you turn the burner knob, and can smell that gas is flowing okay, but the fire won’t ignite, it’s possible that the gas feed is cloggedThis is a super quick and easy fix – simply lift off the grate (make sure it’s cool to the touch), take off the burner cap, and lift the burner out from the range top. For some models, you may need to unscrew the two screws holding the burner in place – for this, a regular nut driver or socket wrench will do the trick.Have a look at the small, nearly pin-sized hole in the back of the burner. This feeds the gas through to the igniter to get the fire lit, and can frequently get blocked up with grease or any other kind of debris. Just give the burner a thorough clean, sticking a toothpick, needle, or other similarly sized tool through the hole to clear it up, and pop it back on to your stovetop. The gas should feed through and the burner should light as usual.
11/25/2020 3:51:58 AM •
Thermador...
Answered
on Nov 25, 2020
