20 Most Recent Hasselblad H2D Digital Camera Questions & Answers
manual
0answers
Hasselblad A16
Be the first to answer 11/30/2017 2:39:03 PM • Hasselblad... • Posted on Nov 30, 2017Be the first to answer
0answers
0answers
Distagon 50mm
Be the first to answer 10/20/2013 11:42:44 AM • Hasselblad... • Posted on Oct 20, 2013Be the first to answer
When I shoot anything that
You can set up the back light correction feature available on the camera menu , reduce the aperture and increase the shutter speed , Additionally the use of correct filters can also help , try not to focus with a back light flashing, avoid the direct but angle it out.
9/28/2010 8:57:49 AM • Hasselblad... • Answered on Sep 28, 2010
6answers
Hasselblad lens jam off camera
Fixing the jammed lens is kind of critical, it might damage your camera if not properly done. You need exclusive tools that can open the lens thus you need to consult or bring your cam to a pro camera technician or to nearest service center
3/11/2009 1:51:21 AM • Hasselblad... • Answered on Mar 11, 2009
1,2,4 hasselblad cft* 80mm speeds runs like 1/30
Those speeds tend to hang up from lack of use. You can try exercising them by cycling through the speeds, but it will most likely need service. The lubrication on the gear train has probably dried up, it is a common problem since those speeds aren't normally used.
10/2/2008 2:54:30 AM • Hasselblad... • Answered on Oct 02, 2008
Digital Harinezumi 2++ won't turn on
It is not well thought of and considered a toy. https://www.google.com/search?q=digital+harinezumi+2+won%27t+turn+on ..
4/20/2024 12:20:14 PM • Cameras • Answered on Apr 20, 2024
My open view is not showing any pictures but showing information about programs playing what might be the problem
Some steps you can try: Check Picture Location: Ensure that the pictures you want to view are in the same folder location. Sometimes, if the images are scattered across different folders, they may not appear correctly in the photo viewer. Repair or Reset the Photo App (for Windows 11): Go to Settings > Apps > Photo. Click on Advanced options. Choose either Repair or Reset to address any potential issues with the Photo app. Enable Thumbnail Previews (for Windows 10): Open File Explorer Options: Type "file explorer options" in the Windows search bar and select the first result. Switch to the View tab. Ensure that the option "Always show icons, never thumbnails" is unchecked. Click Apply and then OK to save the changes. That is about all I can offer. If you repost, include brand and model.
4/19/2024 8:18:20 PM • Cameras • Answered on Apr 19, 2024
2answers
I forgot the combination to my safe can i reset it
limited info generic answer notify manufacturer or locksmith for assistance
4/16/2024 7:20:17 PM • Cameras • Answered on Apr 16, 2024
Activition code digital tv 2050
Free version does not require activation, but unsure if that will work for you. Web site specifically states there is not any activation code and not supported. All of its software is "free, freeware, shareware, full version, trial, demo or open-source" https://www.download.hr/software-digital-tv-2050.html
4/15/2024 9:02:35 PM • Cameras • Answered on Apr 15, 2024
INTERNAL ERROR FREEGROMRIGHT SIZE 1431655766
I don't see anything that resembles 'make model (what it is)'. You posted to the category Cameras? https://www.google.com/search?q=FREEGROMRIGHT+SIZE+1431655766 ..
4/5/2024 1:31:05 AM • Cameras • Answered on Apr 05, 2024
2answers
Where can I get Manual for novar ed&s wireless colour camera
if you purchased the camera from a retailer or reseller, they may have a copy of the manual available.
4/4/2024 12:04:13 AM • Cameras • Answered on Apr 04, 2024
How do you turn on Digivue1.3? Has new batteries and used a while ago but pressing 2 button (Mode, Set) do nothing.
This is going to take patience and maybe the user guide. To turn on the Digivue 1.3, follow these steps: Connect to Your PC: Connect the standard USB cable (supplied) to a free USB socket on your PC. The end of the USB cable should be connected to the socket on the back of the USB digidock. Important: Do not connect any of the cabling provided with the Digivue before commencing the software installation. Install DigiConnect Windows® Software: Insert your Digivue into the docking station. If you are connecting for the first time, a Red LED will display in the Activity Window of the Digivue. Insert the CD provided into your optical disk drive. It will run automatically, and a dialog box will appear. If the autorun feature is disabled on your system, browse to the disk using Windows® Explorer and double-click Setup.exe. If you have a multilingual version of Digiconnect, you will be prompted for your language. Select from the list and click "Next." Accept the terms in the License Agreement and proceed with the installation. Choose the folder for software installation (default is the standard location for Windows® programs). Click "Install" to begin the installation. Leave the box labeled "Launch DigiConnect" ticked and click "Finish." Wait for the Red LED: Wait until a RED LED appears in the activity window of the Digivue. You may now proceed with the next steps. If you encounter any issues during this process, refer to the detailed instructions in the Digivue User Guide on page 9
4/1/2024 1:04:02 PM • Cameras • Answered on Apr 01, 2024
Hello, I would like to know how to solve an error called "ALLARME" "sicur camera"??
Reboot everything. If that doesn't work, Maker Support.
SICUR SERVICE ITALIA
SICUR SERVICE ITALIA https://www.sicurserviceitalia.it ·Translate this page 1.3 MP Camera · 2 Mega Pixel Camera · 3 Mega Pixel Camera · 4 Mega Pixel IR Camera · 5 Mega Pixel IR Camera · 12 Mega Pixel Camera · Speed Dome da esterno ... ..
3/15/2024 2:12:47 PM • Cameras • Answered on Mar 15, 2024
2answers
Which is the best weding photographer in ernakulam
Here are some highly regarded wedding photographers in Ernakulam, Kerala:
  1. Maks Wedding Photography:
    • Located inChelad, Kothamangalam, Kerala.
    • Specializes inwedding photography and videography.
    • Contact:099478 23133.
    • Facebook Page
  2. Lumiere Wedding Company:
    • Based in Ernakulam, Kerala.
    • Their crew beautifully captures emotions during the D-day, creating elegant pictures that will remain etched in your heart forever.
    • They cover weddings not only in Ernakulam but also in UAE, Malaysia, and other parts of the globe.
    • Contact:099951 48014.
    • Website
  3. Euforia Wedding Photography:
    • Located atUzhinjelil Tower, Convent Rd, Ponnurunni, Vyttila, Kochi, Kerala.
    • Offers candid and artful wedding photography packages.
    • Cherish the vibrant traditions and colors of your Kerala wedding with their skilled team.
    • Contact:090481 90403.
    • Website
  4. Dakshin Wedding Services:
    • Exclusive wedding photography and videography company covering events across South India.
    • Address:Js 5, 5th Floor, Heavenly Plaza, Kakkanad, Edappally, Civil Line Road, Ernakulam, Kerala.
    • Contact:070123 90551.
    • More Information
Remember to explore their portfolios, discuss your preferences, and find the photographer whose style resonates with your vision for capturing your special day! These companies use teams. It is difficult to pick out an individual photographer but perhaps you might find what you are looking for at the Lumiere Wedding Company. That company stands out among the four I mentioned.
3/15/2024 10:38:43 AM • Cameras • Answered on Mar 15, 2024
Hi, I am in Dubai,I
FUJIFILM MIDDLE EAST FZE [Subsidiary] Business Field (s): Digital Cameras
Address: P.O. Box 17212, R/A08, HB03, Jebel Ali, Dubai, U.A.E.
Tel: 971-4-883-9990
GRAND STORES [Distributor] Business Field (s): Photographic Film and Paper, Film Cameras, Digital Cameras, Digital Printers, Minilab Systems, Medical Systems
Address: Saleh Mohammed Bin, Lahej Building, Al Garhood, P.O. Box 2144, Deira, Dubai, U.A.E.
Tel: 971-4-2-823700
Dynagraph For Printing Industry [Distributor] Business Field (s): Graphic Systems
Address: Al Quoz Industrial Area, Sultan Al Suwaidi Building, Office No.1, Dubai, U.A.E.
Website:
3/14/2024 5:17:47 AM • Cameras • Answered on Mar 14, 2024
Hi, Have replaced batteries on model Gardenline brand model46715 garden timer and there is no digital screen showing on the timer. It is blank, like it needs new batteries.Can you please help me? Russ
Here are some steps you can take to diagnose and potentially resolve the problem: Check Battery Polarity: Ensure that the batteries are inserted correctly, with the positive (+) and negative (-) terminals aligned properly. Sometimes a simple reversal of the batteries can cause display issues. Reset the Timer: Some electronic devices benefit from a reset. Try removing the batteries, waiting for a minute, and then reinserting them. This action might reset the timer and bring the display back to life. Inspect the Battery Compartment: Look for any signs of corrosion or dirt in the battery compartment. Clean it gently using a cotton swab or a soft cloth. Corrosion can disrupt the electrical connection and affect the display. Test with Fresh Batteries: Even if the batteries are new, they might be defective. Try using a different set of fresh batteries to see if the display turns on. Check for a Backlight or Contrast Setting: Some timers have adjustable backlight or contrast settings. If your model has this feature, try adjusting it to see if the display becomes visible. Contact Customer Support: If none of the above steps work, consider reaching out to the manufacturer's customer support. Remember that the Gardenline brand model 46715 has received mixed reviews, with some users reporting issues related to the LCD screen. While some have had positive experiences, others have encountered problems like fading screens or dead displays . If none of this works, you may need to explore another timer.
3/13/2024 2:39:50 AM • Cameras • Answered on Mar 13, 2024
What type of battery does my TVG it has two batteries
All question need 'make model (what it is) as first 3 words or this happens https://www.google.com/search?q=What+type+of+battery+does+my+TVG+have Guessing is is a mobility scooter, but even so. Google know all the answers, your search query would be make model battery replacement Or just look at what is one the existing ones if you have them. Or Google make model manual Everything is online and my skill is finding stuff. ..
3/13/2024 2:19:59 AM • Cameras • Answered on Mar 13, 2024
Hasselblad H2D Digital Camera Logo
Popular Tags
0 questions posted
Top Hasselblad Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Hasselblad Camera Expert? Answer questions, earn points and help others
View Most Popular
Hasselblad Cameras
  • Hasselblad Cameras
Most Popular Question
free software download
  • Cameras
