20 Most Recent
Sony Xperia U ST25I Android OS v2.3 Cellphone with 3.5-Inch Touchscreen, 5MP Camera, 720p Video Recording, Wi-Fi and A-GPS Support - Unlocked Phone - No Warranty - Black/White Questions & Answers
How to recover photos and videos?
GT Recovery for Windows is a professional data recovery for Android phone or tablet. It can restore deleted photos,videos,audios,documents from Android SD card and internal memory. Whenever you lost important pictures or deleted photos by accident, you can use it to scan and recover the images on your Android devices.
Here are the steps to recover deleted data on Samsung Galaxy S4.
With this way you can recover deleted data on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Wifi & bluetooth settings says error
hello d r sir,
i have problem with my sony xperia st25i that when i try to turn it on,it does not turn on and shows error.so what can i do to fix this problem?
help me please
How do i transfer numbers over from old phone to xperia u st25i?
It depends on the model/make of the phone you have before, but you have a couple of options.
In your contacts, there should be a setting to back-up your contacts. From here, you'll need to choose to back them up to the device or the sim card. If you back-up to the sim card, it will probably limit the number of contacts you can save.
If the old phone is an Android device, you can select to back your contacts up to your google account, after which point, you can relog into your google account on the new phone and the contacts should automatically be synced with the new device.
If you do restore from a sim card, on the new phone, put the sim card into the phone, then go to your settings, within contacts, and import contacts from sim.
So, from the old phone "Export contacts to sim" and on the new phone "Import contacts from sim."
How do I turn off battery on Xperia T that is built in
I'm 100% sure on the Xperia T(I have a ZL) but with most off the Xperia's there is some sort of removable back panel or a hinged flap that opens up under the panel/flap there is a orange button that you will need a pen to press and hold. hold this button down while holding down the power button it should vibrate once, keep holding the buttons then it should vibrate 3 times, now let go of the buttons and your phone should stay off.
Where is the bios
Are you looking for the instructions? There aren't any. Sit down with someone half you age and they'll explain the cell phone to you. I'm not kidding. I can't figure mine out and am waiting for some kid to explain it to me.
Forget my sequrty code
you can retrieve your security code to unlock your phone with the help of a/c which you have registered on playstore....
Open country lock mobile
You want to open the country lock of which mobile?You can approach
Wickedunlock.com and specify the mobile make, model, country,network.Based on the availability you can get the unlock service along with free unlock instructions.
My sonyxperia u has no signal its not the sim
Hello Dear:::::::First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
