20 Most Recent D-Link DSL-G624M (0790069285783) Wireless Router Questions & Answers
Hi. I would suggest resetting the router to factory settings and setting up your wireless network again. There is usually a reset button on the back. Once the remote is reset, run "ipconfig" in the command prompt of your computer to find out the router's IP address. It's usually 192.168.0.1. Type the IP address into the address bar of your web browser to access the router's network setup wizard.
Hope this helps.
D-Link DSL-G624M... | Answered on Aug 20, 2011
You will need to replace the router. This is typical of the failure pattern of all wireless routers. If you continued using the router on the wireless you would begin to notice those connected by wire disconnected and then quickly reconnecting again.
Unfortunetly this is typical of any home grade wireless router after 1-2 years of use or age. About all you can do is to do a hard reset and/or upgrade the router system software. That can regain use of the wifi for a while but it will fail again usually within a few weeks or days.
Best advice is to replace it with a new one. NetGear or D-Links are both reccomended. Linksys is not. If you check out the sales you should be able to find a good replacement for less than what you paid for the one you have giving you trouble. We replace about 2-3 wireless routers a week with these problems. Have tried fixing them even with the factory tech rep on the phone and in the end just ended up junking them.
D-Link DSL-G624M... | Answered on May 25, 2010
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
D-Link DSL-G624M... | Answered on Apr 30, 2010
make sure that your router is acting like a DHCP server.
also make sure that your pc's ip is set to "obtain automatically" under local area connection->properties->internet protocol->properties
D-Link DSL-G624M... | Answered on Jan 25, 2010
Go to speedtest.net for testing your up and down stream info.
D-Link DSL-G624M... | Answered on Oct 06, 2009
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
D-Link DSL-G624M... | Answered on Mar 14, 2009
Hi, you need to log into your D-link router and then you van change your wifi password. in case you need any help mail me on ajay94503@hotmail.com
D-Link Computers... | Answered on Mar 08, 2019
you have to try turning the hole lot off and restarting it i had this problem with putting mine and same with printers good luck should work
D-Link Computers... | Answered on Jan 19, 2019
If using lan just connect the extender to the router with a lan cable. The extender will no need to setup.
D-Link Computers... | Answered on Jan 17, 2019
Without providing a model number I can't be specific. Usually it is admin, admin or admin and no password.
D-Link Computers... | Answered on Jan 04, 2019
Should be able to hook it up to your computer with hard wire and put it in if you don't hook it up that way it won't work
D-Link Computers... | Answered on Dec 26, 2018
If you are facing issue while using Dir 618 configure as a bridge router then i recommend you to once read this blog to get understand the proper concept to use it : https://www.routertechnicalsupportnumbers.com/blog/fix-invalid-wi-fi-ip-configuration-issue-on-windows-10/
D-Link Computers... | Answered on Nov 21, 2018
You need to log into the router using either //router, routerlogin.net. or the IP address which is by default, 192.158.1.1 or 192.168.0.1
Default passwords can be found on the companies website, but many use admin and password
D-Link Computers... | Answered on Oct 29, 2018
D-Link DSL-G624M (0790069285783) Wireless Router Logo
7 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
wlan disconnected
  • Computers & Internet
