20 Most Recent Trampolines BQC1620 Questions & Answers
You can use a patch, but most trampolines fabric is made to stretch, and a patch interferes with that often transferring the stress to another location causing additional wear on the fabric. Best thing to do is to simply replace the entire mat. The weather is pretty ******* them.
Trampolines... | Answered on Dec 27, 2017
May I get the make and model # of the trmpoline to help you more.
Trampolines... | Answered on Dec 25, 2014
Try Gorilla Glue.One of the strongest in the world. http://www.gorillaglue.com/
Trampolines... | Answered on Jan 22, 2011
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Trampolines... | Answered on Sep 05, 2010
When I assembled my 14ft trampoline a few weeks ago the instruction were to attach springs at the 12 and 6 oclock positions then 3 and 9, then symetrically around the perimeter. Disassembly would be the reverse. Start by removing the spring at 12 then 6 oclock, then 3 then 9 oclock. You will always remove the spring 180 degrees away from the last spring removed. This means you'll be running around the trampoline many times but I think the idea is to remove tension evenly so that the mat isn't damaged. Once the springs and mat are removed I expect the frame will easily disassemble. My framo was like curved piping that fit together and is only held in place by spring tension. Hope this helps.
Trampolines... | Answered on Jul 16, 2010
put one on then go to the other side and put another on if you put one on next to the other one you will need to go around to other side and put one on there and so on
Trampolines... | Answered on Apr 04, 2010
hi i was wondering if u got this fixed and if so how did u do it as i have the same prob
Trampolines... | Answered on Oct 22, 2009
fear
Trampolines... | Answered on Sep 02, 2009
Hope this helps. The trampoline net will either have a sleeve for flexible poles to form a ring at the top or there will be at least four obvious "loops" to hang from the poles. Then you need to sew the net to secure it to the mat/trampoline itself with rope. A good idea to buy new rope to do this as it wears with use. I have replaced my securing rope with "tie-down" rope from the sporting good department. The soft nylon kind seems to wear better. To sew: use a good knot to secure it to the underside of the trampoline (spring/Loop) then simple go through the net at the bottom skip a few holes come back through the net and go down around the bottom of a spring hold. repeat all the way around.
Trampolines... | Answered on Aug 17, 2009
one would have to talk to your propane service .
Grilling | Answered 2 days ago
SADLY WE CAN NOT TRY THE MFG'S WEBSITE
Grilling | Answered on Jan 19, 2019
Contact the manufacturer. You need a new controller. They can send you the part either under warranty or for a fee, depending on when you purchased the smoker. They are usually pretty easy to swap out.
Grilling | Answered on Jan 16, 2019
Grilling Logo
24 questions posted
Top Trampolines Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a Trampolines Grilling Expert? Answer questions, earn points and help others
View Most Popular
  • Trampolines Grilling
Most Popular Question
trampoline put together wrong
  • Grilling
