20 Most Recent
Desa International Reddy Heater® RHER70CT Questions & Answers
My pro 100 does not light. Igniter heats up and
The photo eye shuts the unit down if the burner does not burn correctly on startup, ie.if the eye does not see light prior to tiiming out. I would say since it is shutting down, it is working OK. While you say there is plenty of fuel, you do not know if there is the correct ratio of air to fuel. The most common problem on these heaters is the mix. I have a tip at
http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains exactly what you need to do to correct this and where to get the parts to do it. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
3/1/2010 9:26:23 PM •
Desa...
Answered
on Mar 01, 2010
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
2/19/2018 12:59:43 PM •
Desa...
Answered
on Feb 19, 2018
I HAVE A DESA MODEL T36 NRA
I have same model, went to all parts.com and ordered pilot assembly for 105$ , has all in one kit.
Part # 108084-02 easy instal
Good luck
9/24/2013 8:56:59 PM •
Desa...
Answered
on Sep 24, 2013
