20 Most Recent Dell Precision M4300 Core 2 Duo T8300 2.4ghz 3gb 250gb Vista Wifi Dvdrw Laptop Questions & Answers
Replace wireless card
You can open the flap on the bottom of the laptop. There is 2x screws. The card is approx. an inch I'm size - something like this."> I would however not bother and simply purchase a micro USB wireless adaptor and fit that. It takes up a USB port but is very small and hardly noticeable.
7/20/2014 10:03:55 AM • Dell Precision... • Answered on Jul 20, 2014
Hellow Guys, I have Dell Precision T7400, it was working fine, the problem is that in boot manu i cant see Hdd or Cd-Rom,but in bios i see them... any ideas on how to solve this please....!
this 2007 year PC OLD, has many limits (CORE 2 is one) is this windows 10? 64bit> I bet not its CORE 2 old) I came with VISTA if MS loaded OS, or XP or RedHat Linux? what boot menu are you talking about.? F12? wild guess me, VISTA OS: (now zero support) in windows, we have disk manager, do all devices show up now? this is first, if not here, explorer can not work. lets do the correct order: 1: bios sees my media. (good) 2: then in device manager, it sees them, if not drivers bad. 3: then Diskmanager sees the devices, and must have drive letter or next. if letters missing right click device and add one. 4: explorer (This PC) fails to find it. if above fails sure. easy as 1,2,3,4 order, matters. can't see CD does that mean a disk or the whole drive? cant See HDD, is this HDD0 ,1,2, 3 or? how many HDD do you have, and are there SSD drives there and last what SATA ports are you using, some are limited. here is your DELL.com support page, (12 years later still here) https://www.dell.com/support/home/us/en/04/product-support/product/precision-t7400/drivers what HDD fails, does the PC boot at all? my wild guess NO. what OS what OS do you want to run, that be first thing to ask on any 2007 old PC, as Windows 10 will fail here. I Bet. for sure 64bit.
6/30/2019 12:47:15 PM • Dell Precision... • Answered on Jun 30, 2019
Dell Precision PC Desktops keeps restarting
Could be a faulty psu or disk drive - suggest test both
3/4/2018 4:00:28 AM • Dell Precision... • Answered on Mar 04, 2018
Precision 370 won't read flash drive
If not data on the flash drive I suggest try reformatting the drive to remove any malware
3/4/2018 2:55:10 AM • Dell Precision... • Answered on Mar 04, 2018
Dell t5500 won't post with 2GB memory sticks
Many Dell can be a bit funny about exactly what RAM they will accept == check what other owners say on the Dell website user forums ..
3/30/2016 11:30:16 AM • Dell Precision... • Answered on Mar 30, 2016
Computer won't move from 'starting windows' screen
At power-on, use F12 (or F8) and select 'Repair' ... DO NOT let it 'reformat' your drive or you will loose everything .. If that fails, you may have to choose 'Factory Restore', but this will re-install Windows and you will LOOSE EVERYTHING !! SO == if you have another PC, I suggest move your disk drive to that other PC and copy off all your photos/music/videoa etc you don't want to loose before doinbg a Factory Restore ..
3/30/2016 9:52:37 AM • Dell Precision... • Answered on Mar 30, 2016
Were do I connect the monitor to the dell precision t3500
It's simple. If you still have a problem please take a look at manual in pdf file for this dell t3500. You can find it here for example: User manual for Dell T3500
9/19/2015 11:52:51 AM • Dell Precision... • Answered on Sep 19, 2015
I am having a very strange problem with my Windows 10 Desktop PC with renaming
Windows 10 is new and still in testing phase, new patches are released to fix bugs almost everyday. try running an update, make sure your hardware was compatible and the OS is installed properly, you do have the option to roll back if you want to. call 1-877-805-1027 for expert help.
8/21/2015 8:10:15 PM • Dell Precision... • Answered on Aug 21, 2015
What is PCProtect?
PCProtect is malware. What is PCProtect exe . I would boot up in Safe Mode again, or Normal if you have to, and bring up Task Manager again (Ctrl-Alt-Del) and check to see if explorer.exe is running. If not, Click on File in the Task Manager toolbar, select New Task (Run), and type explorer.exe in the Open box and click OK. If all goes well, your icons and Start Menu will appear and you can start cleaning up. Otherwise, you could try again and type appwiz.cpl in the Open box to bring up the Programs and Features to remove any bad programs you may find. Malware removal can takes years of experience, so I will leave it at that to try for a starting point.
7/31/2015 1:46:35 AM • Dell Precision... • Answered on Jul 31, 2015
3answers
Can't find my hard drive
Boot the node up and go into the bios settings, its either f1 or more common f2. Look to see if the hdd is listed. If so try to boot up. If that fails it's time to do a little diagnostics. Get another hdd of the same type and plug it in to see if it boots up. If it does then get a new hard drive. Just something else to try before putting the 2nd hdd in, take the cover off the computer and locate the hard drive and unplug the plug back in the ribbon cable and power connection.
11/25/2014 5:54:58 PM • Dell Precision... • Answered on Nov 25, 2014
2answers
Can you help me with bios password for dell precision m6500 tag no. HR58S4J-2A7B
Remove the BIOS battery, wait a minute the replace it
10/6/2014 12:59:49 AM • Dell Precision... • Answered on Oct 06, 2014
Won"t power up. If I hold the power button down an icon on the lower right flashes on but nothing else happens.
Hi, It is unfortunate that the computer is not turning on. Request you to try following the below steps which might help:
    (1)Turn off the computer. (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc. (3)Press and hold the power button for 30sec which releases the static on the computer (if any) (4)Put back the battery and plug in the AC Adaptor. (5)Let the computer charge for some time. (6)Try turning on the computer. If the computer doesn't turn on then check if the computer gives any series of beeps or if there are any diagnostics LEDs on it. Thanks and Regards. Kiran Kumar. #iworkfordell.
10/3/2014 2:32:40 PM • Dell Precision... • Answered on Oct 03, 2014
Can't find the right driver
Need more info about your computer to answer your Question
7/3/2014 5:51:11 PM • Dell Precision... • Answered on Jul 03, 2014
I have changed power supply of Aspire T180 to upgrade, no response from my desktop
you may have electrocuted motherboard if you did not stay grounded while putting in power unit. touching MB while not grounded can cause really bad issues. if cpu heatsink fan is not spinning when power on, then that would stop boot up. if graphics card boot files corrupted then no boot either. check to see none of the capacitors on MB are swollen at cross+ top. if they are bulging then they could have blown stopping power from reaching MB. things you need to check. also, ac adapter may be bad.
5/19/2014 4:52:18 AM • Dell Precision... • Answered on May 19, 2014
I have a dell precision 690 desktop computer
Your Windows 2000 cd might be damaged.
5/5/2014 5:22:00 PM • Dell Precision... • Answered on May 05, 2014
Testing dell power supply
Why? Buy a new power supply.
5/1/2014 11:44:14 PM • Dell Precision... • Answered on May 01, 2014
Can i upgrad my dell precision m4400 to a quad core
Do you know what socket your motherboard has? What is your Express Service Code on the back of your machine?
4/12/2014 11:27:52 PM • Dell Precision... • Answered on Apr 12, 2014
Dell Precision M4300 Core 2 Duo T8300 2.4ghz 3gb 250gb Vista Wifi Dvdrw Laptop Logo
1 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Precision Dell
  • Precision Dell
Most Popular Question
replace wireless card
  • Computers & Internet
