20 Most Recent
Kyocera Kyo1t02kh0us0 Br Taskalfa 180 1tk437 Sd Black Toner Kyocera Questions & Answers
How do i fix the error c-6000?
from key pad press 1087 1087, the copier will go to maintenance mode ,press 163 then print key , press execute ,you may have to turn copier off the on again, if copier resets it good to go,
if not it will need a new fuser assy.
6/27/2015 11:59:37 PM •
Kyocera...
Answered
on Jun 27, 2015
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
Kyocera Printer wont scan
Check Network Connection: Ensure both devices are on the same network.
Restart Devices: Power cycle both computer and printer.
Verify Scanner Settings: Confirm correct scanner selection.
Update Drivers: Install latest printer drivers.
Firmware Update: Consider updating printer firmware.
Inspect Cables: Check all connections.
Contact Kyocera Support: If issue persists, reach out to Kyocera's support.
Kyocera km 3050 has a new toner but says toner empty
If your Kyocera KM 3050 printer is displaying "toner empty" message, even though you have replaced the toner cartridge with a new one, it's possible that the toner sensor inside the printer is malfunctioning or is dirty. You can try the following steps to fix the problem:
1. Open the front cover of the printer and remove the toner cartridge.
2. Look inside the printer, and you should see a small sensor that detects the toner level. This sensor may be dirty or covered with toner particles.
3. Clean the sensor with a soft, dry cloth and reinsert the toner cartridge into the printer.
4. Close the front cover and power on the printer.
If the problem persists, try resetting the printer's toner counter. Here is how to do it:
1. Press the "System Menu" button on your printer.
2. Scroll down to "Service" and press the "Enter" button.
3. Scroll down to "Maintenance" and press the "Enter" button.
4. Scroll down to "Reset Toner Counter" and select it.
5. Restart the printer and check if the problem has been resolved.
If none of these steps work, there might be a more serious hardware issue with your printer's toner sensor, and it's advisable to contact a Kyocera printer support expert or service center for assistance.
Why is my printer Kyocera Ecosystem P3045dn producing vertical mark on printed sheet?
If your Kyocera Ecosystem P3045dn printer is producing vertical marks on printed sheets, there could be a few potential causes for this issue. Here are some troubleshooting steps you can take:
- Check the print cartridge: Inspect the print cartridge for any damage or defects. Ensure that it is installed correctly and securely in the printer. If the cartridge is low on toner or nearing its end of life, replace it with a new one.
- Clean the print head: The print head may have accumulated dirt, debris, or dried ink, which can cause vertical marks on the printed sheets. Refer to the printer's user manual for instructions on how to clean the print head properly. Use a lint-free cloth or recommended cleaning materials provided by the printer manufacturer.
- Check the drum unit: The drum unit could be dirty or damaged, leading to the production of vertical marks. Remove the drum unit according to the printer's instructions and inspect it for any signs of damage or wear. Clean the drum unit using a soft, lint-free cloth. If the drum is damaged, consider replacing it.
- Inspect the paper path: Check the paper path for any obstructions or debris that might be causing the vertical marks. Look for torn or wrinkled paper, as it can leave residues on the print path. Remove any obstructions and ensure the paper is loaded properly in the tray.
- Adjust print settings: Ensure that the print settings in your computer or printer driver are correctly configured for the paper type and print quality. Adjust the print density or quality settings to see if it affects the appearance of the vertical marks. You may need to experiment with different settings to achieve the desired result.
- Update printer firmware and drivers: Outdated printer firmware or drivers can sometimes cause printing issues. Visit the Kyocera website and download the latest firmware and drivers for your printer model. Install the updates according to the provided instructions.
