20 Most Recent Lenovo ThinkPad 570 (5703BUK) PC Notebook Questions & Answers
The sound totally becomes muted when a data card is inserted in my laptop
There is a conflict between the data card and your sound system or it may require shared files that current sound system uses, there for muting it out so full access is acquired.
4/7/2012 2:02:35 PM • Lenovo ThinkPad... • Answered on Apr 07, 2012
SL500 does nothing when power
remove the battery large. then run on AC pack only #1 top failure of all mobile PC is that battery, so unplug it then test with AC pack only. work now.? and all vents must be clean, end to end. not just fan. there i no fuse it uses current regulator, imagine genius magic electronics fuses that never blow out, and bingo. OK big battery out, an RTC coin cell fresh. then fan blows. next is BIOS, do the BIOS screens work if not the mobo is dead. have 2 RAM stick on the 2 slots>? try one at a time run the PC with all modules removed, (options) remove hdd? remove, dvd drive. think like this. Get bios working first learn that modules can short, and when they do the power regs shut down. so we unplug all things to the mob, until only 1 ram and cpu remains. see? (this is called power overload fault isolation tactics) even the screen only can be dead, you never mention text showing you can test the mobo with external screen via that rear (?)_ VGA jack what if that worked, did you learn something here, sure. this pc has tons of modules to pull, even bluetooth. wifi, sound and more. if you look at all parts inside or sold by ebay, bingo. lots
8/14/2018 12:52:53 PM • Lenovo ThinkPad... • Answered on Aug 14, 2018
2answers
Screen lock
It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):1. Unlock your Android device2. Find the Applications menu and select "Settings"3. Under the "PERSONAL" group, select " Security"4. Under "SCREEN SECURITY" group, select "Screen Lock"This will ask for the security pattern first.5. The options for screen lock will appear, select "Slide" and you are done!Hope this helps.
3/14/2017 5:21:09 AM • Lenovo ThinkPad... • Answered on Mar 14, 2017
How can I activate the camera?
2/16/2016 4:15:32 PM • Lenovo ThinkPad... • Answered on Feb 16, 2016
G500 how reach bios setting
Just press "delete" "F2" or "Escape" keys imediately then you power on your computer. (Key depends on your pc model)
1/8/2016 7:24:01 PM • Lenovo ThinkPad... • Answered on Jan 08, 2016
HOW RESET BIOS PASSWORD TOSHIBA M11
Try this http://www.wikihow.com/Clear-BIOS-Password
1/8/2016 7:18:55 PM • Lenovo ThinkPad... • Answered on Jan 08, 2016
My pointer in my touchpad wont move it will move with my pointer
Do you mean it will move with a mouse, but not the touchpad? If so, maybe settings in this article will help: https://support.lenovo.com/us/en/documents/ht075745
11/26/2015 4:46:51 AM • Lenovo ThinkPad... • Answered on Nov 26, 2015
How do I replace the battery
Battery recall - Lenovo Support (US)
support.lenovo.com/us/en/documents/hf004122
LenovoJul 9, 2015 - These batteries were manufactured for use with ThinkPad notebook ...batteries with new notebook computers or as optional or replacement batteries on the... Which ThinkPad notebook PC models are affected by the recall?
Remove the battery pack - Lenovo Support
https://support.lenovo.com/documents/migr-46510
LenovoJun 17, 2014 - Install charged battery; Slide the battery latches to the locked position. Slide the battery latches; Turn the computer over again. Connect the AC ...
11/20/2015 12:20:11 AM • Lenovo ThinkPad... • Answered on Nov 20, 2015
My ibm thinkpad will not start up although I left the battery charging all night. What can I do?
Remove the battery from the ThinkPad and press and hold the power on button for approx 5 seconds. Replace battery and then try again.
9/7/2015 11:32:16 PM • Lenovo ThinkPad... • Answered on Sep 07, 2015
Lenovo ThinkPad 570 (5703BUK) PC Notebook Logo
2 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
sound totally becomes muted when data
  • Computers & Internet
