FixYa.com
Lenovo Thinkpad T60 PC Notebook
All Products > Lenovo > PC Laptops
Problems with Lenovo Thinkpad T60 PC Notebook?
Troubleshooting and Support
Solved Problems for Lenovo Thinkpad T60 PC Notebook RSS Feed Post a New Problem
how to put extra memory in Lenovo T60...
I check the back side of Lenovo T60 laptop, but still can not find where I can pull out the cover and put more memory in...
2 Solutions
format a laptop
I am not able to format my lenovo T60 laptop. I need to do this early please help me out.
1 Solution
Video card driver
After downloading updates for Vista Ultimate I get the following message: "Hardware acceleration is either disabled...
1 Solution
lenovo laptop not all keys work
not sure of model no.........i have to hold down the function Fn key to get all my keys to work, if i dont i get numbers...
1 Solution
T60 will not boot up
Error message: ERROR 2100: HDDO (Hard Disk drive) initialization error (3)
1 Solution
Unwanted Auto Interruption of Application
Everytime I start or launch any program/application it is always lauch to configure MS Project Professional 2003. This...
1 Solution
Unwanted launching of application
Everytime I launch any application, the said application is interrupted by windows installer trying to configure/instal...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Lenovo Thinkpad T60 PC Notebook RSS Feed Post a New Problem
I can't get my camera to work with my...
I can't get my camera to work with my messenger program, can you help (AOL, Yahoo, MSN)? no puedo usar mi cam en...
Post a Solution
Back-up on Laptop
I have a lenovo T60 and I believe that when the system did some back-ups that it backed the whole system multiple times...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Operating SystemMicrosoft Windows XP Professional · Microsoft Windows XP Home Edition
ProcessorCore Duo 1.66 GHz · Core Solo 1.6 GHz · Core Duo 166 MHz · Core Duo 500 MHz · Core Duo 2 GHz · Core Duo 1.83 GHz · Core 2 Duo 1.6 MHz · Core 2 Duo 1.8 MHz · Core Solo 1.66 GHz
Installed Memory512 MB (DDR2 SDRAM) · 256 MB (DDR2 SDRAM) · 1 GB (DDR2 SDRAM)
Display14.1 in. SXGA TFT Active Matrix · 15 in. · 14.1 in. · 15.4 in. · 14.1 in. XGA TFT LCD · 15 in. XGA TFT LCD · 15 in. SXGA+ TFT Active Matrix · 14.1 in. SXGA+ TFT Active Matrix · 15.4 in. WSXGA+ TFT Active Matrix
Mobile TechnologyIntel Centrino Mobile Technology · Wi-Fi Certified · Intel Centrino Duo Mobile Technology
Hard Drive40 GB · 60 GB Serial ATA, 5400 RPM · 40 GB, 5400 RPM · 80 GB Serial ATA · 100 GB · 60 GB · 80 GB · 1000 MB · 40 GB Serial ATA, 5400 RPM · 100 GB Serial ATA, 5400 RPM · 60 GB, 5400 RPM · 80 GB Serial ATA, 5400 RPM · 1000 MB Serial ATA · 60 GB Serial ATA, 7200 RPM · 60 GB Serial ATA
Processor
Processor TypeCore Duo · Core Solo · Core 2 Duo
Processor Speed1.6 GHz · 166 MHz · 1.66 GHz · 2 GHz · 500 MHz · 1.83 GHz · 1.6 MHz · 1.8 MHz
Processor ManufacturerIntel
Processor Numbert2300 · T2400 · T1300 · T2500
Motherboard
Bus Speed667 MHz · 677 MHz
ChipsetIntel 945PM express · Intel 915GM · Intel 945GM Express
Memory
RAM TechnologyDDR2 SDRAM
Installed RAM512 MB · 256 MB · 1 GB
Installed Cache Memory2048 KB
Max Supported RAM4.096 GB · 3.072 GB · 2.048 GB · 1.536 GB
RAM Speed667 MHz · 533 MHz
Hard Drive
Hard Drive Capacity60 GB · 100 GB · 1 GB · 40 GB · 80 GB
Storage Controller TypeSerial ATA
Hard Drive Rotation Speed5,400 RPM · 7,200 RPM
CD / DVD
Optical Drive Read Speed24x (CD) · 8x (DVD)
CD / DVD TypeDVD-ROM · CD-RW/DVD-ROM · DVD-RW / CD-RW · DVD±RW · DVD±RW/CD-RW · CD-RW/DVD+RW · DVD RW/CD-RW · Dual Layer DVD RW · DVD RW
Optical Drive Write Speed24x (CD)
Optical Drive ReWrite Speed24x (CD-RW)
Display
Display Size14.1 in. · 15 in. · 15.4 in.
Display TechSXGA TFT Active Matrix · XGA TFT LCD · SXGA+ TFT Active Matrix · WSXGA+ TFT Active Matrix
Display Max. Resolution1024 x 768 · 1400 x 1050 · 1680 x 1050
Display Color Support24-bit (16.7 million colors)
Video
Installed Video Memory64 MB · 128 MB
Graphic ProcessorATI MOBILITY RADEON X1300 · ATI MOBILITY RADEON X1400 · Intel Graphics Media Accelerator (GMA) 950
External Video Resolution2048 x 1536 · 1600 x 1200
Graphic Bus InterfacePCI Express
Audio
Audio Output TypeSpeaker(s) · Sound Card · Headphones
Audio Input TypeMicrophone · Line In (3.5mm) · Line In (3.5mm)
Operating System
PlatformPC
Technical Features
Expandability1 x Type I/II PC Card Slot, Docking Station/Port Replicator, 1 x ExpressCard · 1 x Type I/II PC Card Slot, 1 x ExpressCard · 2 x Type I/II PC Card Slot, 1 x ExpressCard · 1 x Type I/II PC Card Slot, Docking Station/Port Replicator · 1 x Type I/II PC Card Slot, 1 x SD Card Slot, 1 x Memory Stick Card Slot, Docking Station/Port Replicator, 1 x MMC Card Slot, 1 x ExpressCard
Input MethodKeyboard · Touchpad · Trackpoint · Ultranav · Numeric Keypad · Dualpoint · Embedded numeric keypad · One Touch Access Buttons
Security FeaturesHDD Password, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, IBM Security Slot, Security Chip (TCPA/Crypto 3) · Finger Print Sensor, HDD Password, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, IBM Security Slot · Finger Print Sensor, HDD Password, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, Security Chip (TCPA/Crypto 3) · HDD Password, Slot For Cable Lock, Power-On Password, Administrator Password, Security Chip (TPM) · Finger Print Sensor, HDD Password, Slot For Cable Lock, Power-On Password, Administrator Password, Security Chip (TPM) · Finger Print Sensor, HDD Password, Power-On Password, IBM Embedded Security Subsystem 2.0, IBM Security Slot · Finger Print Sensor, HDD Password, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, Security Chip (TPM) · HDD Password, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password · HDD Password, Slot For Cable Lock, Power-On Password, Administrator Password · Finger Print Sensor, HDD Password, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, IBM Security Slot, Security Chip (TCPA/Crypto 3) · HDD Password, Slot For Cable Lock, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password · Finger Print Sensor, HDD Password, Slot For Cable Lock, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password · HDD Password, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, IBM Security Slot, Security Chip (TPM) · Finger Print Sensor, HDD Password, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, IBM Security Slot, Security Chip (TPM) · Finger Print Sensor, HDD Password, Slot For Cable Lock, Power-On Password, Administrator Password, Security Chip (TCPA/Crypto 3) · Finger Print Sensor, HDD Password, Slot For Cable Lock, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, Security Chip (TPM) · Finger Print Sensor, HDD Password, Slot For Cable Lock, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, Security Chip (TCPA/Crypto 3) · Finger Print Sensor, HDD Password, Slot For Cable Lock, Power-On Password, Administrator Password · Finger Print Sensor, HDD Password, Power-On Password, Administrator Password, IBM Security Slot · HDD Password, Slot For Cable Lock, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, Security Chip (TPM) · Finger Print Sensor, HDD Password, Power-On Password · Finger Print Sensor, HDD Password, Power-On Password, Administrator Password, Security Chip (TPM)
Expansion Ports3 x USB 2.0, VGA out, RJ-11 (modem), RJ-45 (NIC) · 3 x USB 2.0, 1 x IEEE 1394a (FireWire), VGA out, RJ-11 (modem), RJ-45 (NIC) · 3 x USB 2.0, VGA out · 3 x USB 2.0, RJ-11 (modem), RJ-45 (NIC), S-Video out · 2 x USB 2.0, VGA out, RJ-11 (modem), RJ-45 (NIC) · 3 x USB 2.0, VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out · 3 x USB 2.0, VGA out, RJ-11 (modem), RJ-45 (NIC), DVI (Digital Video Interface) · 3 x USB 2.0, VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out, DVI (Digital Video Interface)
Networking
Data Link ProtocolEthernet · Fast Ethernet · IEEE 802.11b · Gigabit Ethernet · IEEE 802.11a · IEEE 802.11g · Bluetooth · CDMA · EV-DO
Networking TypeInfrared Port · Integrated Wireless LAN · Integrated 10/100/1000 Network Card · Bluetooth
Modem
Modem TypeFax / Modem · Wireless Cellular Modem
Analog Modulation ProtocolITU V.92 · ITU V.90
Cellular Enhancement ProtocolCDMA · GPRS
Battery
Battery TechnologyLithium ion
Battery Run Time9 Hours · 4.3 Hours · 6 Hours · 3.6 Hours · 5.9 Hours
Dimensions
Depth10 in.
Height1 in.
Width12.2 in.
Weight6.6 lb.
Warranty
Warranty3 Years · 1 Year
World Wide WarrantyYes · Yes, Limited
Supported Models
00882861280650, 195101U, 195124U, 195126U, 19512KU, 195137U, 195143U, 195144U, 195145U, 195147U, 19514KU, 19514NU, 1951C2U, 195243U, 195244U, 1953D5U, 1953D6U, 1953D7U, 1953D8U, 1953D9U, 1953DAU, 1953DDU, 1953P3U, 200702U, 200704U, 200723U, 200743U, 200744U, 200747U, 200748U, 200749U, 20074AU, 20074BU, 20074CU, 20074DU, 20074EU, 200755U, 200756U, 200758U, 200759U, 20075BU, 20075CU, 20075RU, 20075TU, 200762U, 200763U, 200767U, 20076KU, 200772U, 200774U, 20077DU, 2007C2U, 2007C3U, 2007C4U, 2007C5U more...
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
