20 Most Recent
Samsung LN-T3232H Television Questions & Answers
Samsung lcd tv has sound but no picture
Do you have back lighting. Shine a light on the screen. If you can barely see a picture the set has no backlight but video is good. This would rule out the main board. Not shure if this set is LED backlight or flouresent tube back light. If flouresent tube check for voltages to inverter board. 24v or 15v. They are marked on the board. If voltages are there likely inverter board. or could be power brd. Check pricing on new tv.
10/2/2013 8:07:14 PM •
Samsung...
Answered
on Oct 02, 2013
Screen goes blank
Will you please provide more details about the problem you faces with this TV?
11/3/2012 11:17:38 PM •
Samsung...
Answered
on Nov 03, 2012
Ps3 wont work on my ln t3232h says not supported
Very easy fix guys. all you gotta do is use either your component cables or hook the ps3 up to a different TV than change you output settings from 1080 to 720p, thats the reason your not getting an image is the ps3 is set to a 1080i or 1080p output, but the tv is only capable up to 720p. good luck ^^
12/5/2011 5:14:07 AM •
Samsung...
Answered
on Dec 05, 2011
I have audio, but no picture: when I first turn
usually the back right on but no picture, and the 12v to t-con ok. May be the t-con failure. But even it is true, you have to ensure it match with the panel (what model of the panel the t-con use for). LNT3232HX/XAA has 8 different versions, use 8 different panels and 10 different t-con board.
Also the main board or LVDS cable defective, could cause this issue.
6/10/2010 4:11:59 AM •
Samsung...
Answered
on Jun 10, 2010
One side of my tv gets dim and out of focus it is a samsung. At times it works fine
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
How do I troubleshoot my Samsung TV?
I have sound, but no picture.
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
My Samsung Tv modle LN46C600F3F has sound no picture, what could be wrong?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
