unable to get bbc 1, 2 or news since switchoff on our digital tv, retuned several times but to no...
(More)
unable to get bbc 1, 2 or news since switchoff on our digital tv, retuned several times but to no avail. Can still get bbc 4 and all the radio stations. TV is a SONY KD 28DX40U
Rexcently purchased a samsung 22 inch LA22B450 and it comes in a hotel mode. I think I made a...
(More)
Rexcently purchased a samsung 22 inch LA22B450 and it comes in a hotel mode. I think I made a mistake and set it up in hotel mode, and now I can't access the menu to tune the cahnnels in. All I can do is adjust the volume and channel buttons. How can I reset so I can set it up again from scratch?
Hello, I have a Samsung LCD 26'' television which is experiencing some serious image...
(More)
Hello, I have a Samsung LCD 26'' television which is experiencing some serious image sticking/retention problems. First thing I noticed was a wavy shaped blob, in that blob the screen was much brighter than normal, taking up 1/8 of the screen in the top right corner, I didnt take much notice at first but then around it I started noticing that any images left in one place for more then 2 minutes near it would stick in a purple ghost image. Now it's got to such an extent that the whole TV is retaining these images. Anything left in one place for more than 1 minute is now stuck all over the TV and as I said, A ghost purple image.
The internal freeview tuner has locked up on ITV 1, on my Samsung lcd tv. none of the DTV related...
(More)
The internal freeview tuner has locked up on ITV 1, on my Samsung lcd tv. none of the DTV related buttons work. I have tried rebooting from the analogue set up menu but the "plug and play" option stops when it gets to the DTV bit!! How can I reboot the DTV tuner?
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Anyone with AKAI problems can download their service manuals at http://esi.fox-international.com. Just select the product type and a list will...
written by Kongsberger
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
Composite x 1 · Audio (RCA) x 1 · RF x 1 · Audio (Mini Jack) x 1 · S-Video x 1 · Component x 2 · DVI x 1 · 1 x D-Sub (RGB PC) · HDMI x 1 · 21-pin Scart x 2
