Samsung LCD-television 16:9 32"  "HD ready" DVB-T LE32R73BD 32 in. HDTV-Ready LCD Television
Problems with Samsung LCD-television 16:9 32" "HD ready" DVB-T...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Samsung LCD-television 16:9 32" (82 cm)...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Samsung LCD-television 16:9 32"  "HD ready" DVB-T LE32R73BD 32 in. HDTV-Ready LCD Television RSS Feed
View More Results for Samsung LCD-television 16:9 32" "HD ready" DVB-T LE32R73BD 32 in. HDTV-Ready LCD Television
Questions and Unsolved Support Problems
Unsolved Problems for Samsung LCD-television 16:9 32"  "HD ready" DVB-T LE32R73BD 32 in. HDTV-Ready LCD Television RSS Feed
Answer
i've got perfect sound but a red line appeared on screen and now i've got no picture at all can you... (More)
Answer
samsung 32 inch lcd tv, line across screen about 1.4 way down, shows on when watching sky and also... (More)
Answer
my samsung tv screen keeps switching on n off when i switch it on
Answer
My car remotes doesnt work as of today, replaced batteries which was unnecessary since green light... (More)
Answer
how do you retune a samsung lcd tv type LE32R73BD?
Find a Manual
Samsung LCD-television 16:9 32" "HD ready" DVB-T LE32R73BD 32 in. HDTV-Ready LCD Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
tv in
always check the cables that are feeding the tv written by crcelect
Lamp vs Ballast
This is to help explain the short lives of Lamps. WARRANTY: If a lamp fails within the first year replace Lamp and Ballast. If Lamp explodes do not... written by BIG IRISH
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen.... written by mlapres
Tv troubles
the newer tv are just computors in disguyes.they often won't come after a power surge and have to be reset,you must unpluge from the wall and wait 10... written by bsddog87
Falt Panel Screen Cleaning
If you are trying to clean a LCD or Plasma screen, use only recommended screen cleaners. Be very careful not to rub too hard or contrast coating may... written by edcor
TV has snowy picture or displays unusable signal, no signal or no sync.
What to do if you have an all snowy picture, blue screen or the TV displays unusable signal, no signal or no sync. When using a Satellite receiver or... written by johnnydiode
how to test flyback without taking it out of the board
a) basically it has to be acted upon by a supply voltage of at least 95V to work. b) of course, assuming the horizontal deflection oscillator works,... written by palaboy
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Samsung LCD-television 16:9 32" "HD ready" DVB-T LE32R73BD...
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Samsung LCD-television 16:9 32" (82 cm) "HD ready" DVB-T...
Samsung LCD-television 16:9 32" (82 cm) "HD ready" DVB-T LE32R73BD 32 in. HDTV-Ready LCD Television
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Rate and Review the Samsung LCD-television 16:9 32" "HD ready" DVB-T LE32R73BD 32...
Write a review:
Rate this product:
Would you recommend the LCD-television 16:9 32" (82 cm) "HD ready" DVB-T LE32R73BD 32 in. HDTV-Ready LCD Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Samsung LCD-television 16:9 32" "HD ready" DVB-T LE32R73BD 32 in. HDTV-Ready LCD Television
Key Features
Screen Size
32 inch
Contrast Ratio
5,000:1
Digital TV Standard
HDTV-Ready - Requires separate receiver to view HDTV signals. · HDTV-Ready Television
Flat Panel Type
LCD Television
Display Resolution
1366 x 768 pixels
HDCP Support
With HDCP Support
Display Capabilities
Built-in Tuner
NTSC · PAL · SECAM
Digital TV Standard
Broadcast Format Displayed
480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Interpolated Aspect Ratio
16:9, 4:3
Native Aspect Ratio
16:9
Image Quality
Brightness
500 cd/m²
Viewing Angle
178
Adjustable Color Temperature
With Adjustable Color Temperature
Remote Control
Remote Control
Standard
Illuminated Remote
Non-Illuminated
Audio Features
Audio Type
Virtual Surround
MTS Stereo
SAP / MTS Stereo
Audio Leveler
With Audio Leveler
Technical Features
Picture in Picture
With PIP
Parental Control
Proprietary
Sleep Timer
With Sleep Timer
Connectors
Headphone Jack
With Headphone Jack
Rear Input Connectors
RF x 1 · Audio (Mini Jack) x 1 · Component x 1 · Audio (RCA) x 2 · 1 x D-Sub (RGB PC) · 1 x RS-232C · HDMI x 1 · 21-pin Scart x 2
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output Connectors
Audio (RCA) x 1 · 21-pin Scart x 2 · Optical Digital
Screen Text
Channel Labels
With Channel Labels
Closed Caption on Mute
Without Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Dimensions
Depth
3.15 in.
Height
21.59 in.
Width
31.5 in.
Weight
32.63 lb.
Samsung Contact Information
Main support number1-800-SAMSUNG
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
