20 Most Recent Sony KDL-26U2000 26 in. LCD Television Questions & Answers
get a better antenna
Sony KDL-26U2000... | Answered on Apr 23, 2017
dear customer please check purchase date television warrenty or out of wareenty .televesion open & check fuej .now reconect fuje system working fine.
Sony KDL-26U2000... | Answered on Mar 02, 2012
Check the power to the TV by plugging something else into the socket.. If it is getting power the power supply of the TV will need to be looked at by an engineer.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Sony KDL-26U2000... | Answered on Feb 22, 2011
Try to unplag the power cable for 15min.
Sony KDL-26U2000... | Answered on Jan 10, 2011
Checking your remote can be done with any digital camera since they can 'see' the infrared light from them but I suspect the remote is working; generally, if they are emitting anything, it will be sending correct correct pulse trains.
Having the camera 'live' you will be able to see that the remote is working by aiming the remote at the camera's lens and pressing any button while watching the camera's LCD display. The output of the remote will appear as white or near white blinking lights.
> I've tried to reset to factory settings but when I've got into the service menu I can't input anything?
Often the service settings require entering some code (password) sequence to access factory settings and it may not be possible to enter the code if one or the other end of the IR system isn't functioning.
Summary; I think the remote transmitter is OK but the receiver in the set is not decoding the received signal despite it indicating that something was received.
I think the set itself is a fault and you will need a tech on site on in the shop to search for the right board to replace since the IR receiver may be part of the main board (expensive) or a separate assembly (somewhat less expensive).
Sony KDL-26U2000... | Answered on Jan 01, 2011
The retuning process is as follows:
  1. Press the [i+] button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If toy wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
Sony KDL-26U2000... | Answered on Oct 03, 2009
HDMI outputs from devices such as DVD players do carry both video and audio, but the HDMI output from your computer video card only carries video. You'll need to connect a cable from the computer sound output to the TV as well.
Sony KDL-26U2000... | Answered on Feb 25, 2009
cheak back light settings turn it all way up if down to low it will buzz in video options
Sony KDL-26U2000... | Answered on Nov 10, 2008
sounds like inverter problem
Sony KDL-26U2000... | Answered on Nov 10, 2007
The problem in most of the case are:
1. Interference from a defective fluorescent lamp at your room sending signals to the infrared receiver of the TV.
2. Defective infrared receiver itself that sending noisy control signals to the CPU.
3. Defective manual control withes it has leakage.
4. Water damaged control switch PC board.
Sony KDL... | Answered on Oct 30, 2017
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sony KDL... | Answered on Jun 29, 2017
Sony KDL-26U2000 26 in. LCD Television Logo
Popular Tags
23 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
KDL Sony
  • KDL Sony
Most Popular Question
one tv
  • Televison & Video
