FixYa.com
Acer AT3705-MGW 37 in. LCD Television
All Products > Acer > Flat Panel Televisions
Problems with Acer AT3705-MGW 37 in. LCD Television?
Troubleshooting and Support
Solved Problems for Acer AT3705-MGW 37 in. LCD Television RSS Feed Post a New Problem
digital tv
I bought a acer AT3705-MGW tv from germany and can't figure out how to use the inbuilt digital reciever as all the...
1 Solution
samsung syncmaster 400p
screen is locked up ( blue ), & buttons dont work to change anything
Post a Solution
Just a consumer quesstion.
Would it be a bad idea to mount my LCD tv above my fireplace? There is a recess in the wall above it and it seems like...
1 Solution
lcd tv shuts down by its self
I have a magnavox 32mf231d lcd tv that shuts down after about 10 mins. If left alone it will restart by its self after a...
Post a Solution
32" lcd acer tv picture gone
tv is just over a year old, used for about 20-30 hours. Screen has gone green. You can still make out images but faces...
Post a Solution
Television "locked"
I was watching television last night and changed channels. all of a sudden, the screen went blank and it said locked at...
1 Solution
optical output on tv through dvd home...
I HAVE A NEW 40IN SAMSUNG LCD HD READY TV AND SAMSUNG DVD HOME CINEMA WITH A HDMI AND OPTICAL CABLES FITTED BUT THE...
Post a Solution
View All
Unsolved Support Problems
Unsolved Problems for Acer AT3705-MGW 37 in. LCD Television RSS Feed Post a New Problem
ACER AT 3705 SCREEN
THERE ARE TWO PALE PURPLE HORIZONTAL LINES ACROSS THE TOP AND BOTTOM OF THE SCREEN.THOUGHT IT WAS INTERFERENCE BUT IT...
Post a Solution
Tuning problem
Everytime I switch my TV on it loses all its channels and I have to retune them. When I switch it on the TV is all fuzzy...
Post a Solution
AT3705-MGW
I'm using the AT3705 with Vista Media Centre and when I try and set the resolution to 1920x1080 @ 30hz the TV has blurry...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen Size37 inch
Contrast Ratio800:1
Flat Panel TypeLCD Television
Display Resolution1920 x 1080 pixels
HDCP SupportWith HDCP Support
Display Capabilities
Built-in TunerPAL · SECAM
Broadcast Format Supported1080p (HDTV)
Broadcast Format Displayed1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV) · 1080p (HDTV)
Native Aspect Ratio16:9
Image Quality
Comb Filter3DYC / 3D Digital
Brightness550 cd/mē
Output Color16.7 million colors
Viewing Angle176
Adjustable Color TemperatureWith Adjustable Color Temperature
Remote Control
Remote ControlStandard
Illuminated RemoteNon-Illuminated
Audio Features
Audio TypeVirtual Surround
MTS StereoWithout SAP / MTS Stereo
Technical Features
Picture in PictureWith PIP
Parental ControlProprietary
Sleep TimerWith Sleep Timer
Connectors
Headphone JackWith Headphone Jack
Memory Card SlotCompactFlash Card · SD Card · MMC Card · Memory Stick · Memory Stick Pro
Screen Text
OSD LanguagesEnglish · French · Spanish · German · Italian
Closed Caption on MuteWithout Closed Caption On Mute
Speakers
Number of Speakers2 Speakers
Speaker Power2 x 15 Watt
Dimensions
Depth11.22 in.
Height28.5 in.
Width46.65 in.
Weight79.3 lb.
Acer Contact Information
Main support number408.432.6200 1.800.733.2237
Support FAX408.922.2933
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
