20 Most Recent
Tatung LD30HL Television Questions & Answers
THE T V WILL NOT
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
Is the tatung v23cltt built in 2003 an hdtv?
Televisions that lack high definition will neither need nor have HDMI capability. Older televisions will not require the 1080p connection that HDMI provides. If yourtelevision is not a flat screen, LCD or plasma, then it will not have HDMI capability.
Turning off
If you have 3 capacitors bad, there are likely more that you missed.You didn't mention what kind of Flat Panel. If LCD, then check for the 5 volt supply. The caps are likely 220uF and 1000uF - 1500uF and all in the 16 volt range.
