Does anyone have the part number for a Power Supply for a trutech PLV16260 Television. many thanks...
(More)
Does anyone have the part number for a Power Supply for a trutech PLV16260 Television. many thanks howard
Hi, I'm attempting to set up my RCN remote cable to my Trutech TV, but am having absolutely no luck...
(More)
Hi, I'm attempting to set up my RCN remote cable to my Trutech TV, but am having absolutely no luck whatsoever. Any suggestions?
No picture on screen sound works fine any suggestions or just junk it - is an under the cabinet...
(More)
No picture on screen sound works fine any suggestions or just junk it - is an under the cabinet model used in our kitchen
Did you get your TV fixed?Here is how you can fix it yourself if you want to.If not,please let me...
(More)
Did you get your TV fixed?Here is how you can fix it yourself if you want to.If not,please let me know what you would like for it,and I'll buy it from you. Open the back of the TV,and look at the can shaped items called capacitors on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.Most of the time the big black capacitor on the power board goes bad,and bottom bulges out,but sometimes it is the other capacitors as well.I hope this helps.If you have any questions,please let me know.Thank You very much! Tyler
Hi there, I msg'd you a while back in regards to purchasing your broken trutech 26" tv - has...
(More)
Hi there, I msg'd you a while back in regards to purchasing your broken trutech 26" tv - has there been any progress so far in your search for a fix? If not, could you please consider selling me your broken unit so i can fix mine? =) Please contact me at masonholdings@gmail.com as soon as it is convenient for you, and thanks in advance!! Mason
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
