20 Most Recent
VeriFone Eclipse Quartet Questions & Answers
Ink not printing to paper
sometimes the injector at the ink cartridge is cloged/stuck
I have lightly soaked a cotton Q TIP in alcohol then, gently rubbed it several times over/against the area where the cartridge injectors are, caring that no cotton fibers are left and it has worked out the problem. You may try it a second time if at first intent did not work
Hellp me to downloud drievr
Go to the Verifone website, look up your printer, and you should find what you need in your Support section.
Have verifone 801 printer - prints game and fish
NOTE: The inside cover of the printer has medialoading instructions for vendors.
- Open the lid of the printer by pressing in on the two (2) Blue buttons on both sides of the printer, and lift upward.
- Press down on the Green Printhead Latch, and raise the Printhead Carrier assembly to a vertical and locked position.
- Remove the Ink Ribbons (Supply and Take-up Hubs/Spindles) from the Printhead Carrier by pushing in, and lifting up.
- Slide both ribbons off the hubs, and discard them into the trash.
- Slide an empty core onto the take-up hub. (The attached new roll of ribbon includes a new supply hub.)
- Unroll a 1-foot length of ribbon. (The foiled side will need to be facing the Printhead and rollers.)
- Insert the supply hub/ribbon into the rear spring-loaded spindle.
- Starting from the back of the Printhead Carrier, thread the take-up hub/core in between the black guide bar and the two (2) aluminum rollers.
- Continue past the Printhead, and over the 3rd aluminum roller.
- Insert the take-up hub into the spring-loaded spindle 'star' hole.
- Position the license paper (media) over the rubber roller to the edge of the opening with one hand.
- With your other hand, lower the Printhead Carrier to its locked position.
- Close the printer lid.
Vx610 verifone change prefix to dial 9
It all depends on the application. It would be best to contact your technical support service to have the prefix added to the programing parameters they are hosting for you. Then you can download the new parameters using your 9 prefix by editing the *ZP prarameter to include 9,18#########. To add the , press * ALPHA.
