20 Most Recent Toshiba Portege M100 Notebook Questions & Answers
normally means the screen connection is broken take it to get fixed normally costs only $80
Toshiba Portege... | Answered on Apr 27, 2014
Try to download camera drivers on their site check if it the same brand your laptop your using
Toshiba Portege... | Answered on Dec 04, 2013
Yes the CMOS battery needs to be changed. Then you can go into the BIOS and set the Date & Time.
The CMOS/BIOS will be set back to the defaults when you remove the CMOS battery and this may fix your problems.
Toshiba Portege... | Answered on Sep 16, 2012
You should be able to use an external keyboard....just plug a usb keyboard in and boot up...this is probably your cheapest solution and will get you up and running again quickly :-)
Toshiba Portege... | Answered on Aug 27, 2012
Making a bootable flash drive involves a few tricks. I have had much better success using a utility to do the setup on those. Doing it manually works but not all the time.
I'd beg borrow or buy a usb dvd drive and boot off the install cd if nothing else. These have really dropped in price and are handy to have around.
I'm assuming you have set the bios to boot from the flash drive before it hits the hard drive? You would also have to set it to hit the usb dvd drive prior to the hd as well if you go that way.
When you get it booted it will ask if you want to format the drive before installing. You can also just pick a new directory to put windows in as well.
Don't forget to download all the drivers from Toshiba. You will need system info, video, and a network at the very least to get running and able to download the rest. These are very handy on a flash drive to plug in when you get xp started.
Toshiba Portege... | Answered on Sep 02, 2011
To remove the BIOS password on this model, you'll need a parallel port, which comes on a port replicator or a dock cause the laptop doesn't come with one. After that, you'll need to make a parallel port password key (buy an old, parallel port cable, cut it, locate the schematics http://www.cgsecurity.org/wiki/CmosPwd, and connect the appropriate wires), and that'll do it.
Toshiba Portege... | Answered on Aug 22, 2011
Sounds like a bad optical drive. Good thing is: this thing uses a SelectBay removeable drive and it's a one touch remove type. Same as the ones used in the more popular Tecra 9000, Tecra 9100 series. I'd replace it. Best source is eBay. Price target? Under $15 delivered.
Most DESKTOP computers have a jumper to "clear CMOS settings",
but most NOTEBOOK computers do NOT have that jumper.
The password exists to protect the owner of the computer, should a thief be trying to use the computer.
You probably can remove the disk-drive, and copy the files onto a new computer, if you don't want to pay TOSHIBA to bypass the password.
Toshiba Portege... | Answered on Apr 15, 2011
In restoring your system back to factory settings, you will need the recovery disc. The title of it is "Application and drivers".
Or go to this site http://www.mytoshiba.com.au/support/items/faq/71
Toshiba Portege... | Answered on Mar 12, 2011
is ther any led marker wath signs?
Toshiba Portege... | Answered on Mar 04, 2011
I don't know what the connector the HDD uses is called, but I do have a pinout if your interested.
Toshiba Portege... | Answered on Feb 26, 2011
how to break password
Toshiba Portege... | Answered on Dec 30, 2010
if you upgraded to windows 7 driver files are in windows.old folder
Toshiba Portege... | Answered on Nov 09, 2010
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Toshiba Portege... | Answered on Oct 16, 2010
Toshiba Portege M100 Notebook Logo
47 questions posted
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Computers & Internet
Most Popular Question
want sound driver toshiba m100
  • Computers & Internet
