20 Most Recent Acer Aspire 1640Z Notebook Questions & Answers
You can try ?
turn off your moderm, turn off your wireless access point (2 minutes) and restart your computer.
Acer Aspire... | Answered on Sep 09, 2018
There could be a motherboard problem or a screen problem, but everyproblem with the screen on my acer laptop was fixed on the motherboard, so you should probably take it in a repair shop
Acer Aspire... | Answered on May 15, 2017
What's the question?
Acer Aspire... | Answered on Dec 28, 2015
I don't see the Acer images in the screen when I change the sound, no escale at green or when I try to play other screen doesn't appears the window option? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
1742SEA1P 715G1492 1 ACR Acer ADTV1742SEA1P Power Supply Backlight...
Acer Aspire... | Answered on Jan 27, 2015
had the same problem, but product still covered by warranty. Came back working with screen replaced. Could also be backlight fault and/or invertor board.See you tube for how to replace and test to eliminate various parts. Good luck.
Acer Aspire... | Answered on Jun 18, 2014
Acer have all the drivers on their website.
You can go there - Acer.com and select Support / downloads and search for your model.
then select OS - XP,VISTA, WIN7/8 and download and run.
Acer Aspire... | Answered on Dec 21, 2013
This unit was shipped with P home edition and would have been supplied with possibly 4 CD's (system disk and 3 recovery disks)
All the drivers and applications will be on the system disk, you need to insert cd into drive and it will autoboot and select the sound drivers, if still not working then possibly windows is corrupted and you will need to recover the notebook by booting from system cd at startup then follow onscreen instructions, hope this helps.
Acer Aspire... | Answered on Dec 20, 2013
1 long 2 short is almost always video/RAM related, if you've replaced the RAM, the it's most likely the mainboard that the RAM connects to.
Unfortunately the portege's always have very expensive replacement parts, you're probably looking at about $300 for a new board and then whoever you buy it from will add a large markup. Be careful buying boards for Toshiba's off of ebay as they quite often use variations on the same board for multiple models. You'll find a large model number on the bottom of the machine starting with PS this will help you track down a board if you want to.
I would reccomend a new computer.
Thanks,
Liam.
Acer Aspire... | Answered on Sep 17, 2013
You need to reinstall the audio drivers. Go here: http://support.acer-euro.com/drivers/notebook/as_1640.html Good luck:)
Acer Aspire... | Answered on May 02, 2013
Have you considered a Exorcist? Have you cleaned the fan, vents, heatsink recently? Take a look at this it may help in troubleshooting: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Acer Aspire... | Answered on Apr 30, 2013
The keyboard won't light huh? WELL THAT'S BECAUSE IF YOU READ THE MANUAL IT SAYS; " (TIP: KEYBOARD DOES NOT LIGHT)" SO NEXT TIME READ BECAUSE I HAVE ONE SO! YEAH! NOT TO BE MEAN BUT READ!
Acer Aspire... | Answered on Mar 25, 2013
Please try to insert another disk for testing.
If nothing works then try to check with another DVD rom for testing.
If the other DVD rom not working then this is registry of windows problem
If other DVD rom works then your original DVD rom is faulty.
Acer Aspire... | Answered on Mar 05, 2013
Hello.
Disconnect the power adapter.
Remove battery
Remove Monitor screws in hinges.
Remove Strip with Power-On button - feels sticky
Remove keyboard screws
Remove keyboard - may need gentle side to side movement
Remove optical drive screw
Hope this helps.
Acer Aspire... | Answered on Feb 23, 2013
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Acer Aspire... | Answered on Jan 10, 2013
You should be able to get XP 32-bit SP3 added. However, Windows Update will not work with XP SP2. Thus you will need to manually download the update and then install it. This is the link to the update: http://www.microsoft.com/en-us/download/details.aspx?id=24 . Click on the Download button. This is the version usually used for computers that aren't on a network.
I hope this helps.
(the Acer 1640z came with XP SP2; most computer companies support all of the service packs for their originally installed OS.)
Acer Aspire... | Answered on Dec 16, 2012
Acer Aspire 1640Z Notebook Logo
Popular Tags
258 questions posted
Ekse
Alun Cox
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer aspire 1640z
  • Computers & Internet
