20 Most Recent Weber Summit Platinum C4 (LP) Grill Questions & Answers
Can you hear or small gas? It's possible to may have turned the propane tank valve on too fast. Close the tank valve, disconnect it, then reconnect it. Slowly turn the tank valve back on and try lighting it again. Hopefully this is your solution, but let us know if you need more assistance. Or check out my Tips & Tricks for gas grill lighting problems, just click on my user name and scroll down to my Tips & Tricks and see if any of those solutions help.
Douglas
Weber Summit... | Answered on Jun 04, 2010
Contact weber to see if they have a conversion kit. The venturi for propane and natural gas are different sizes due to the different burning properties of the gasses.
Weber Grilling | Answered on Feb 11, 2018
Fixya is unable to determine parts sources.
Weber Grilling | Answered on Feb 09, 2018
any BBQ shop that sells weber
from weber manufacturer parts store
Weber Grilling | Answered on Feb 01, 2018
Cooking times are dependent on much more than weight. The shape of the roast, the thickness, the uniformity, the outside temperature, the quirks of your grill... the only way to cook a roast properly is with a probe-type thermometer. You decide what temperature you want the center of your roast and cook it until it reaches that temperature. Be sure to cook over the cool side of a two-zone fire and rotate every once in awhile to even out which side faces the fire side.
Weber Grilling | Answered on Jan 09, 2018
probably about 3 hours but check internal temperature with a meat thermometer after 2 and cook until it gets to at least 160
Weber Grilling | Answered on Dec 24, 2017
turning the knob adjusts the flame intensity
it is not doing that and the flame is very low
low gas in the cylinder
regulator
blocked jet for the burner
Weber Grilling | Answered on Nov 20, 2017
If he really installed a 54 foot line instead of a 54 inch line, the line is way to lone. The gas pressure isn't high enough to supply enough gas to the grill to get any hotter.
Weber Grilling | Answered on Oct 23, 2017
They have adapters for this. Try Home depot
Weber Grilling | Answered on Sep 02, 2017
https://www.cooksillustrated.com/how_tos/6519-properly-assemble-a-weber-charcoal-grill-that-wont-collapse
I would find an image of the specific model of Weber that you have. Maybe several images of different angles of this. Those images may reveal what has gone awry. Some of those images may be at sites selling them, others obtained by a Google IMAGES search.
Weber ORIGINAL KETTLE PREMIUM Assembly Manual
Weber Grilling | Answered on Aug 23, 2017
you can change them but you need to change the jets there are conversion kits for the weber cooking systems.
Weber Grilling | Answered on Aug 06, 2017
Did you check to be sure the seal in the regulator is intact? When you "reset" the regulator did you open all the control knobs to blled out the gas line? Also is this the original regulator that came with your grill?
Weber Grilling | Answered on Aug 02, 2017
Weber Summit Platinum C4 (LP) Grill Logo
Popular Tags
1 questions posted
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
View Most Popular
Weber Grilling
  • Weber Grilling
Most Popular Question
grill will not ignite even manually
  • Grilling
