20 Most Recent Canon Imageclass Mf8080Cw Wireless Multifunction Laser Printer, Copy/F Questions & Answers
These problems occurs when the scanner is unable to take a copy of the image that you are trying to scan.You can go to settings and run a scanner motor test on the scanner.Just check out the results of the scanner motor test.If the scanner motor test results are positive,then please clen the scanner bed with a cotton cloth and then perform a power drain on the printer.
Now in order to perform a power drain you need to keep the printr powered on n unplug the power cable from the back of the printer.And then press the power button down for 30-50 secs n then release it.Then plug in the power cable n turn on the printer. The scaner will respond. But if the scanner motor test results are negative, then the scanner needs to be fixed by a hardware technician
Canon Imageclass... | Answered on Dec 16, 2013
if you want the DEFATUL IP ADDRES JUST RESET THE PRINTER AND CONNECT THE PRINTER WITH COMPUTER AND SCAN THE PRINTER WITH ADVANCED IP SCANNER SOFTEWARE
Canon imageCLASS... | Answered on May 20, 2019
imageclass mf 4412 e 202-0002
Canon imageCLASS... | Answered on Apr 29, 2019
The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
Canon imageCLASS... | Answered on Apr 14, 2019
I guess youve tried switching it off and on?
If so It needs its system software reloading. Only Canon reps can get hold of this, best to get someone locally.
Canon imageCLASS... | Answered on Apr 07, 2019
That error is related to the scanning section , maybe the image reading unit is defective
Canon imageCLASS... | Answered on Mar 17, 2019
My Cannon MF3010 Printing and Photocopy slowly work. How can fix it?
Canon imageCLASS... | Answered on Jan 29, 2019
That jam code is from one of the doors of the machine, i hope this can help you
Canon imageCLASS... | Answered on Dec 16, 2018
1) The ir400 copier laser scanner has a number of fans that generate the signal. The fan number 5 is the curl reducing fan.
2) If any error occurs from that fan, then you will see the 004-error code. The error occurs when the fan wiring is faulty.
3) The fan can be faulty or even the DC controller PCB can also damage. There can be any foreign objects objecting the fan's rotation pathway.
4) If you find any object, then remove the object. Check if the wiring and the connector of the fan are normal.
5) Replace the fan if there is a problem with it. Also, replace the DC controller. Check if the fan FM5 is positioned correctly.
6) The Heat Exhaust Fan FM5 error can also occur. Check if the connector connection between the Heat Exhaust Fan and the DC controller is intact.
For more printer related support visit our website https://goo.gl/NyDCTc.
Canon imageCLASS... | Answered on Nov 12, 2018
1) The error E808 occurs when one of the connectors in the fixing assembly is not properly plugged in when the unit is on.
2) This might have occurred while replacing the fixing assembly or performing a troubleshooting attempt on the machine.
3) You can find the connector above the fixing assembly at the right corner, behind the cover on the machine's side.
4) To clear the E808 error, unplug the machine from the power supply for at least 10 minutes. The error will appear again if the thermistors are in bad condition.
5)The fixing film assembly should be replaced in such case.
For more printer related assistance get in touch with our experts by just giving a call @ 1-866-293-9220.
Canon imageCLASS... | Answered on Oct 29, 2018
The problem is with the DC controller board, either bad connection or bad board.
Canon imageCLASS... | Answered on Sep 19, 2018
Canon Imageclass Mf8080Cw Wireless Multifunction Laser Printer, Copy/F Logo
2 questions posted
Clive
Clive
old marine
old marine
View Most Popular
imageCLASS Canon
  • imageCLASS Canon
Most Popular Question
not scanning or copying
  • Office Equipment & Supplies
