20 Most Recent
Canon Imageclass D420 All-in-one Laser Printer Questions & Answers
Printer jams when duplexing
Most printer jambs are caused by a couple of things. Have you tried different paper? Sometimes paper that is curled, or if the humidity is too low, the paper will hold a static charge and cause paper feed problems. The other is worn or dirty feed rollers, try cleaning the feed rollers with isopropyl (rubbing) alcohol.
I want to contact to canon xerox service centre kolkata
http://www.xerox.com/about-xerox/contact-us/enin.html
Contact Us - Xerox
Find a local Office Products dealer in your area: Kolkotta Office Xerox India Limited 37, Shakespeare Sarani, 1st Floor, Kolkata - 700 071. Sales: 033 - 44004875 ...
- Copiers like the Xerox personal copiers offer functionality that takes into consideration ... 8/1, Lalbazar Street, Room No.1 D ,1st Floor, Kolkata - 700 001, India.
http://www.copier.in/photocopiers/personal-copiers.html
Canon ir 1024 iF shows E808 code error. How can it be fixed?
1) The error E808 occurs when one of the connectors in the fixing assembly is not properly plugged in when the unit is on.
2) This might have occurred while replacing the fixing assembly or performing a troubleshooting attempt on the machine.
3) You can find the connector above the fixing assembly at the right corner, behind the cover on the machine's side.
4) To clear the E808 error, unplug the machine from the power supply for at least 10 minutes. The error will appear again if the thermistors are in bad condition.
5)The fixing film assembly should be replaced in such case.
For more printer related assistance get in touch with our experts by just giving a call @ 1-866-293-9220.
Ir 2204error code e002-0000
The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
