20 Most Recent
Toshiba Tecra M2 Notebook Questions & Answers
I have a Toshiba Tecra
remove the battery and main AC adapter .press power button 15sec. also pls insert ac adapter and power on.
The bios says 'NO DRIVE". I
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
How do i restore to factory settings?
I have researched Toshiba website. They do not list replacement system DVD/CD there. Did find a listing on Ebay but the item was sold. Checked the manual and there is no information on restoration within it. The result is that I do not see any easy answer for you. You could contact tech support @ Toshiba, generally pay for the call and requrest from them the restoration software. Or you could buy XP CD install the CD and acquire from online the drivers for the computer. Regret that the choices are not better.
No or low sound
Connect an headdphone to the PC and see if there is sound.If present the speakers need a checck or the pins. If not open control panel- device manager and check the audio properties. Reinstall the drivers and see if the sound returns if not there can be problems in the mainboard.
The keyboard is not working
Connect an external USB keyboard, if there's no problems with it then remove your laptop's keyboard. First: Disconnect the ribbon connection and reconnect again
Second: If that doesn't fix the problem
Third: Buy a replacement
If the external USB Keyboard doesn't work you may have some software issues
Toshiba Tecra M2 Not boot up past BIOS ...
On some laptops, holding down FN key when you turn it on, puts you in a diagnostic mode so you can check things. next thing would be to alternate memory.
kind of thinking might be a keyboard problem though (connected to Motherboard so it could be connected to that)
anyway, try an external keyboard. might have to disconnect the laptop keyboard if external keyboard dosent come up for you.
