20 Most Recent
ASUS A3Ac Notebook Questions & Answers
Asus a3a laptop
Probably the AC Adapter is no good....Go to e-bay and purchase a new AC Adapter for that model # notebook. But if it shows charging then try first by taking out the battery and see if the AC adapter will run the computer without the battery in it (if so, then the adapter is good, the battery is actually bad, so replace the battery instead).
Good Luck.
12/4/2013 7:05:32 AM •
ASUS A3Ac...
Answered
on Dec 04, 2013
I cant install my audio
Click your start menu -> All Programs -> Windows Update and download Service Pack 1 from the website that launches.
12/30/2010 7:03:00 AM •
ASUS A3Ac...
Answered
on Dec 30, 2010
ASUS A3A - whats the maximum ram
max memory is 2GB ddr2 533
If you dont have sp1 or later, 137gb is the maximum HD
If you have service packs installed then you can have as big HD as you want.
You may need to use a disc partitioning program to get the full use out of large HD's
12/19/2010 3:54:11 AM •
ASUS A3Ac...
Answered
on Dec 19, 2010
Give me cd drive data
Windows 2000 and XP and Vista and 7 all have "built-in" support for CD-ROM drives.
9/30/2010 6:11:56 PM •
ASUS A3Ac...
Answered
on Sep 30, 2010
My notebook suddenly shut down
> no option to let me select
This means that no "bootable" CD-ROM was loaded into the CD-drive, *AND* that the "bootable" files could *NOT* be read from the disk-drive.
> it show no hard-disk install
Well, it shows that either:
* no electrical power is reaching the disk-drive
* the electronics "underneath" the spinning-part of the disk-drive have failed
* the "spinning" part of the disk-drive is not spinning (dead motor?)
* the disk is spinning, but nothing can be read from the disk-drive.
Try connecting the disk-drive to another computer.
If it is detected, that's good.
If not, then your disk-drive has a BIG problem,
and replacing it (with or without exercising any "warranty'") is your only way to move forward.
9/30/2010 6:11:15 PM •
ASUS A3Ac...
Answered
on Sep 30, 2010
WHAT IS THE MAXIMUM MEMORY
max memory is 2GB ddr2 533 also known as pc4200.
If you dont have sp1 or later, 137gb is the maximum HD your system will see. If you have service packs installed then you can have as big a HD as you want. You may need to use a disc partitioning program to get the full use out of large HD's
9/3/2010 10:34:30 AM •
ASUS A3Ac...
Answered
on Sep 03, 2010
Cam software
From what i can gather theres no built in camera and you havent said which cam you heve. Tell us which model camera you have and i'll tell you where to download the software
11/1/2009 6:35:19 AM •
ASUS A3Ac...
Answered
on Nov 01, 2009
Webcam failure
Double check you drivers for the webcam to see if they are still working.
Go to control panel, system, device manager (hardware for XP).
Locate your web cam, IF you see a RED X than your driver is messed up or missing.
I would try reinstalling your software for the web cam. Either via cd or go to the vendor's web site.
9/25/2009 4:09:51 AM •
ASUS A3Ac...
Answered
on Sep 25, 2009
