20 Most Recent
Toshiba Satelite A135-S2286 Notebook Questions & Answers
Pc starts but cannot open windows
I think your windows directory has been corrupted. So try to insert the CD of the OS you've installed and do recovery process. If it doesn't resolve your problem, then reinstall the OS.
My toshiba displays pex, check cable
That blue screen sounds like a kill screen to me. Meaning either one HUGE virus hit you or a lot of mini website viruses got past your protection. Only way to fix a kill screen is by performing a factory default right when the laptop turns on so it does have a chance to get you.
Restored my toshiba laptop and now it want start up
The image it the top left corner, a cursor? Is there any Media in the DVD rom? CD? DVD? No, Repeat the restore process. You did a restore to a earlier date? Or a Full Factory Restore? Unplug, remove battery, plug in, reboot. Any Change?
How to restore a toshiba satellite a135-s2286 notebook without cd?
the f8 function is only to try and remedy boot problems. the recovery option you're getting is to restore if you have already made recovery discs.if you have a recovery partition on your hard drive you should be able to access it when you boot up. before starting your laptop press and hold 0(zero) key and power on the laptop. once it starts you should get a screen with 3 options then choose option 1 to get back to factory restore.
I lost my laptop password please help me
Restart the computer, While the computer is restarting hold down the f8 key and you will be prompted with a black and white screen with the option to boot in safe mode, select boot in safe mode, once the "safe mode" desktop loads go to your user account and change your password for your account. Hope this helps, If not let me know thanks
How do you put a key back on a laptop keyboard.
You have to get the sissor part back on first,
there are 4 small i-holes in a square on the keyboard,,
on the sissor part there is 4 small nubs on each corner, thay clip into the 4 i-holes,,
the key itself just clips down on the sissor part.<---Make sure its lined up b4 pushing
Computer shuts off when in bios
Does it matter when the ac adapter is plugged in, or your battery is in? You could be looking at a failing motherboard or possible bad ram. I would first try both power options, and then take your hardrive out to see if it still happens. If it does, then take each piece of RAM out too see if that is causing the issue.
Most likely the end result will be either a failing motherboard or a bad CMOS battery.
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
