20 Most Recent
Weber Summit Gold D6 (NG) Grill Questions & Answers
How do the burners come out for replacement. I see
Hi pdistefano,
Here is a webpage with instructions on how to rebuild a Weber gas grill. You'll find instructions on disassembling the burners in the article. You might find the whole article and the site interesting: http://www.ehow.com/how_7225194_rebuild-weber-grill.html
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
How do I remove burner
The burner ends (the tips farthest from you) are either held in place with a sheet metal screw or the tip fits it a small slot. Either way, removing the burners is the same. If it has a sheet metal screw - remove the screw and lift the burner up and toward the back of the grill. While lifting the burner, pull if away from the front of the grill, so that it slides off the the venturi valve and the burner will lift out.
That's about all there is to it. To help you further, I have included a link to your Owners Manual, that you can download and print for future reference.
http://www.weber.com/help/manuals/pdf_files/Summit_Gold_D_NG_41996_03_27_03_Revised.pdfHappy Grilling!!
Conversion
Click on the Weber link below for customer support and the nearest location that can service your grill. http://support.weber.com/
Weber com Parts Support
