20 Most Recent
Toshiba Satellite P105-S6084 Notebook Questions & Answers
Does my laptop have an dvi port
If it has one that should not be too difficult to find. Look around the
sides of the laptop for a white rectangular port as on the screen
capture below.
Older
laptops have a VGA port and maybe an S-Video port (like the round one
on the image.) Newer laptops may have an HDMI port. DVI-to-VGA adapters
are available at computer accessories shops.
9/15/2012 9:38:58 AM •
Toshiba...
Answered
on Sep 15, 2012
Does my laptop have an dvi cable port
If it has one that should not be too difficult to find. Look around the sides of the laptop for a white rectangular port as on the screen capture below.
Older laptops have a VGA port and maybe an S-Video port (like the round one on the image.) Newer laptops may have an HDMI port. DVI-to-VGA adapters are available at computer accessories shops.
9/15/2012 9:37:53 AM •
Toshiba...
Answered
on Sep 15, 2012
I shut down the laptop
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
7/13/2011 7:27:54 PM •
Toshiba...
Answered
on Jul 13, 2011
Will not start. HDD power light comes on for about
It could be a faulty battery. Remove the battery & try to power up the laptop.
If
the laptop did not power up after removing the battery, then notice the
power receptacle where you plug the power adapter's cord to the laptop.
While plugging the power cord in, notice if there is a spark occurring
at the power receptacle. If the spark occurs, then disconnect internal
drives & connectors one at a time until subsystem with short is
identified. If power input still a short with bare motherboard, replace
the motherboard. If the spark did not occur, then inspect the boards for
burnt or melted components, cold solder on DC jack, open connections,
or unseated cards.
2/7/2011 1:34:27 AM •
Toshiba...
Answered
on Feb 07, 2011
There is a transparent column on my toshiba
If the problem is also on an external display then maybe Windows Side Bar is loaded with no gadgets.
Otherwise a replacement screen is the answer.
See ebay for prices and availability.
12/13/2010 3:46:15 PM •
Toshiba...
Answered
on Dec 13, 2010
Sound driver
Hi lbrugni ,
Below are the link to download the Sound Driver for your Computer. Please open the link in a new Internet Explorer window. Then, you can save the file on the Desktop and double click on it to begin the installation. After installation, please restart the Computer for the settings to take the effect.
Windows XP (Version: v3.11.0.51; 08-30-2006; 1.75M)
http://cdgenp01.csd.toshiba.com/content/support/downloads/conexant_audio_os2006203a.exe
Windows XP (Version: 3.44.0.0(v3.44.0.0; 11-06-2007; 1.17M)
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_audio_conexant_os2007336b.exe
Windows Vista (Version: v3.18.0.51; 02-02-2007; 2.3M)
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_audio_conexant_25636A.exe
Good Luck!
Hope this helps.
Please post back if you have any questions or require any further assistance.
Thanks for using FixYa.
11/5/2010 3:18:35 AM •
Toshiba...
Answered
on Nov 05, 2010
I did a restore on my toshiba satellite and now i
Check your device manager in controll pannel and see if your network drivers are installed.
if any components show up in device manager with a yellow exclamation mark, you will have to install drivers for them.
If they show up with a red X, just right click and try to enable them.
6/3/2010 7:02:16 PM •
Toshiba...
Answered
on Jun 03, 2010
I have a toshiba p105 s6084 and after win xp was
You need to know the maker of your display card in the laptop. Once you have that information you can visit their site and download the appropriate diverrs for your adapter. Pess "Start" and goto "help and support" ->'use tools to view.....->'advanced system information'->view detailed system information'->'components'->'display'.
The name of your display adapter will be displayed at the top of the list, like this..>.Name Radeon X300/X550/X1050 Series.
4/18/2010 1:31:31 AM •
Toshiba...
Answered
on Apr 18, 2010
Left side of screen blacked out,two or linnes in rest of screen
Hi there
The Problem is from the flex of your laptop.The flex is what connects the screen of your laptop to the motherboard of the laptop.The more you close and open the laptop the flex gets weak and that is what causes what you are seeing on your screen
To solve this problem get an expert to change the flex of your laptop for you
Cheers
3/3/2010 9:10:36 PM •
Toshiba...
Answered
on Mar 03, 2010
Has power, but will not post up or go thru boot
Hello my friend,if you sure that is having power and is not motherboard or CPU error then you should try resetting your bios settings or check if the bios battery is dead.You should take it to a repair shop to take a look or tell me if you want to try to change the cmos battery but remember that the warranty will be void and you may harm your computer.
2/6/2010 6:52:46 PM •
Toshiba...
Answered
on Feb 06, 2010
NO power
Check the battery of your notebook pc .
when you charging it then try to turn it on if it starts and shuts down when you remove charging them there must be problem of the battery,then you have to change your battery from Toshiba service center.
10/23/2009 3:51:24 PM •
Toshiba...
Answered
on Oct 23, 2009
