20 Most Recent
Acer TravelMate 2451WLMi Notebook Questions & Answers
My Notebook acer travelmate 2450 doesn't start
Check with someone you know to see if they have a USB external CD or DVD drive that you can borrow. Then set it to boot from USB. There is also a possiblity that you have a corrupt CMOS fireware. See if you can download an BIOS firmware update and place it on a external floppy and install. Good Luck
My FN+F6 doesnt keep my screen on the laptop open
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
Recovery CD
Other way to restore ur notebook to factory default settings without recovery disks is
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
U can make a new set of Recovery disk when ur OS is running u will see Acer Empowering Technology with e sign kindly select ERecovery in the options and then u can make full backup of ur OS thru it
Pls rate me FIXYA fo rhelp
Display
Can u see bright screen when ur Ac adpator is pluged in.
if u can,
then,
change the battery setting in the power management options.
set use maximum battery option.
I need guide
Try the Acer website and check the support for your model see if you get any where with that
My laptop after being turned on a blue screen appears and then shuts down
There are many reasons this can be happening. Try starting the computer in Safe Mode with Networking and see if the problem still exists. If not that means there's a problem with the start up boot process. Questions to consider: How old is the machine? Have you done all your updates? Possible virus. What exactly does the Blue Screen read? Is it a quick blue screen then restarts or does the blue screen stays? We are computer service company that offers remote free diagnosis. Call us to today at (877)608-4574 or visit us at www.aplusonsite.org.
HOW DO I DOWNLOAD FACEBOOK ON MY TABLET
I found out in Google that this tablet has Windows 8 on it.
You can install Facebook on it by going to the "Microsoft Store".
If it didn't install, check if your operating system is 8.1
Let me know if that helps.
Why will it not turn on
try taking out the battery and unplugging the power cord from it and then holding down the power button for the count of 5 the long way 1 one thousand two one thousand ect.... this will drain back the power from the board and it just might boot after you plug everything back in again and try to power it back on
