20 Most Recent Gateway MT3418 Notebook Questions & Answers
0answers
0answers
0answers
It won't turn on
Check thisIf you remove the battery, disconnect the power cord, let the PC sit 5 mins, then hold down the power button for about 30 seconds. THEN, reconnect the power cord (battery still out of laptop), it will probably start up properly. Put the battery back in after the startup.I don't know why or what this indicates, but it works 90% of the time.I've read that resynching the battery will help, but I see no better sucess rate after trying that.Ciao Y'all,Bob
10/10/2013 1:12:46 AM • Gateway MT3418... • Answered on Oct 10, 2013
The transformer box is getting
hi I guess your battery pack is need to replace thats why your adapter is getting hot due to battery pack leakage and is not charging normally. thanks
5/28/2011 11:31:33 AM • Gateway MT3418... • Answered on May 28, 2011
My Gateway mt3418 has dead video card what is
Typically, installing a video card will have to be done by the manufacturer. Finding this type of part, especially from Gateway, will be very difficult. Installing the part will be even harder.
Getting this fixed may be more than the actual laptop is worth.
Contact Gateway for pricing.
3/2/2011 8:43:17 PM • Gateway MT3418... • Answered on Mar 02, 2011
Computer wont power on although both lights come
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad
9/18/2010 12:24:14 AM • Gateway MT3418... • Answered on Sep 18, 2010
How do I replace a gateway laptop motherboard
Replacing the motherboard is very sensitive and one of the difficult things to do when it comes to laptop for the reason because its very compact, if you are not an expert it is strongly not recomended to do that as you may face many problems doing it r doing that may give rise to other problems.In that case please counsult a technician.
However if you want to do it, first of all unplug the power remove the battery and then you have to take out all the screws at the bottom chasie and then you will be able to remove the motherboard.
See manuel for diagrams and more help.
7/25/2010 2:03:02 AM • Gateway MT3418... • Answered on Jul 25, 2010
Lenovo s 10-2 shows black scree
ur device had got formatted install a new window
4/26/2010 10:19:41 AM • Gateway MT3418... • Answered on Apr 26, 2010
Can i replace the graphics hardware on an mt3418
No, but you can fit an Xpresscard graphics adaptor
4/18/2010 7:24:24 AM • Gateway MT3418... • Answered on Apr 18, 2010
Black screen upon boot
try to remove the battery and unplug the power adapter. press power button for 30 sec. then connect power adapter. check if the pc able to turn on
4/7/2010 1:15:43 AM • Gateway MT3418... • Answered on Apr 07, 2010
W340uv touvh pad works but cannot use it to click
Make Sure You Have It Enabled In The TouchPad Settings In The Control Panel.
1/31/2010 6:38:30 AM • Gateway MT3418... • Answered on Jan 31, 2010
How do you turn off the wireless on the mt3418
Press the BLUE FN Button along with F2 to turn off and on the WIRELESS NETWORK - under the mouse pad (far left light) will tell you if you did it correctly; ON = WIRELESS ON & OFF = WIRELESS OFF
12/9/2009 4:06:29 AM • Gateway MT3418... • Answered on Dec 09, 2009
I can not get the sound card to work w/o having to
Hello.Try installing software like driver magician or driver detective that are specialized in finding the exact driver for any harware details.
8/5/2009 11:45:03 PM • Gateway MT3418... • Answered on Aug 05, 2009
Gateway 3418 wont boot - no video
Sounds like the charger board has a short or the ac adapter is malfunctioning.The battery itself may be the cause but not likely.
8/5/2009 11:03:50 AM • Gateway MT3418... • Answered on Aug 05, 2009
Wireless card/driver not working properly.
If it is indeed a hardware problem, and your wireless card cannot be repaired or coaxed into giving you better reception, I would advise buying an external adapter. You can get a cheap USB adapter for under $20 that may suit your needs. That is certainly a better solution than paying for an operating system, assuming that you don't already own it.
The software should not affect your computer's performance, so reinstalling vista will probably not work. Realtek has awful drivers, so I'm not surprised that you are unable to connect.
While deterioration of the card should not be able to occur, I have had it happen with my equipment as well, and it may be a symptom of extreme temperatures, if your laptop gets really hot.
Signal deterioration can also occur if your router has been moved towards solid metal objects (walls, too) or if new networks have been introduced in your area (causing interference)
6/22/2009 11:48:51 PM • Gateway MT3418... • Answered on Jun 22, 2009
Gateway MT3418 Notebook Logo
28 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
M Gateway
  • M Gateway
Most Popular Question
replace graphics hardware mt3418
  • Computers & Internet
