20 Most Recent Everex NM3500 Laptop Questions & Answers
you can download a password reset disk, google it
Everex NM3500... | Answered on May 26, 2013
Good day, to locate your ram follow these steps:
- Laptops often have their RAM located on the underside of the system. Some systems place the RAM right under the keyboard.
- Locate the memory bay. It is usually a sliding panel.
- If you open the bay to the hard driver instead, look for the other sliding panel.
- You may need a small philips screwdriver to unscrew the panel, or, as below, you may need to simply need a flathead to lever the panel upwards for removal.
Hope this information help you a bit. Have a great day.
Everex NM3500... | Answered on May 25, 2011
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Everex NM3500... | Answered on Jan 19, 2011
Use Google Translate: http://translate.google.com/?hl=en&tab=wT# Find out how to switch it back to English by translating the Spanish.
Everex NM3500... | Answered on Dec 12, 2010
One reason that you need to pay for tech support for this laptop is because of out of warranty and most of the time, you will have to pay for any technical support that you may have. I suggest that you try to make sure that the lan of this laptop is working properly by making sure that the driver is installed. Since you've tried wireless, try also the wired connection. Use ethernet cable from your router or modem to your laptop. Then try connecting to the internet.
Everex NM3500... | Answered on Oct 11, 2010
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Everex NM3500... | Answered on Sep 08, 2010
unplug it to reset it
Everex NM3500... | Answered on May 01, 2010
Navigate to control panel in the start menu.
Click System then hit the system tab and go to device manager.
See if there is any yellow circles with exclamation marks.
If so you are missing drivers. I suggest running microsoft update, being sure to select optional updates as well, as this will include hardware updates and will find missing drivers for any hardware that might be missing them. Hope this helps!
Jesse
Everex NM3500... | Answered on Jan 07, 2010
Here is the site for the Atheros wireless card that was installed into Everex laptops.....
http://www.atheros.cz/download.php?atheros=AR5005G&system=1
Everex NM3500... | Answered on Nov 16, 2009
Hello chandra,
This model of Presario has an audio controller that supports the high definition audio. You need to have Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio installed on the computer before installing the audio driver.
Here is the link for the Microsoft Universal Audio Architecture driver that need to be installed before installing the audio driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
After installing the UAA driver reboot the notebook and install the audio driver from the following link:
Conexant CX20549-12 High Definition Audio driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35940.exe
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Click on + sign nest to the Sound, video & game controllers and right click on "AUDIO DEVICE ON HIGH DEFINATION BUS " or Conexant High defination audio entry and click Update driver.
3. Select "Not at this time", click on next and Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp35940 folder and the double click the (WinxP -> Thrifty10 -> CPL30A5a.inf file for Audio) Select the .inf file, click open and Continue with the onscreen instructions.
Everex NM3500... | Answered on Feb 14, 2009
Go into Control Panel --> System --> Device Manager. Look for a Sound device or unknown multimedia device. Try updating the device to Realtek audio. Vista should have it's own Realtek audio drivers. If you can't find it, go here...
http://www.everex.com/support/nm3500w/nm3500w_downloads/nm3500w_downloads.htm
for driver downloads. Honestly, I'm not sure if the Realtek driver listed there is the proper one, but it's the only one listed. Post back with how it goes.
Everex NM3500... | Answered on Jan 04, 2009
if u have driver disk or source thene go to my computer then devicemanger then right clik any icon there then u see scan for hardware changes.
then folowthe proceduree then one step is come for browse then select your source of driver then it install.
Everex NM3500... | Answered on Nov 15, 2008
Everex NM3500 Laptop Logo
33 questions posted
Top Everex Computers & Internet Experts
k24674
Alun Cox
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Everex Computers & Internet
Most Popular Question
doi download sound video drivers
  • Computers & Internet
