20 Most Recent
Fujitsu LifeBook E8110 Notebook Questions & Answers
Notebook Lifebook E8110 - some keys sometimes dont work
support.
fujitsupc.com/CS/.../supportsearch.do?...
Notebook%20PC
USB 3.0 devices not working as Super Speed when resuming from Standby ... Fujitsu LifeBook T734 Notebook PC; Softex OmniPass; Microsoft Windows 7; Microsoft ....When setting up external monitors on the VGA or DVI port do not change the .... Vista and XP Tablet PC act differently at this point; both need to make some ...
I have a Fujitsu-Siemens Lifebook
User and Administartor passwords are only for your OS.
Windows® for Example
To reset your BIOS password, you must disconnect your laptop-battery.
Wait a few minutes, and put it back in.
Now your BIOS password has been reset and you can access your BIOS again.
I have a fujitsu e8110
To reset the BIOS password read the information from this
link.
In your case I would suggest using Hiren's Boot CD as none of the others worked. There is a program called Kill CMOS which wipes the BIOS.
I forget the password of
Disconnect the battery, unplug it, then open it up. There should be a small round battery called the CMOS battery somewhere in there. Pull that out. Then plug your computer in and boot it up without the CMOS battery. It should say password disabled. Turn it off, disconnect it, put it back together, and you're good to go.
Need help
your problem could be that the hard drive is broken, perhaps with some tool to repair hard disks the problem. test starting for example hiren boot from a memory or cd and see if it recognizes the hdd, if so you can pass some repair tool
How can i reset bios code ?
remove the bios password by removing the
cmos battery, removing the jumper from the pins right next to the battery, marked something like pswd, plugging it in and hitting the start button.Before you open the
case, unplug, remove the bettery, then hold the start button to get rid of any energy.
Keyboard
Sounds like liquid may have been spilled on the keyboard.
Plug in an external usb keyboard and check if it works.
If so, you will need to buy a replacement keyboard and swap it out, best cheap from Ebay.
