20 Most Recent
Fujitsu Siemens LifeBook® C1410 PC Notebook Questions & Answers
Lifebook c1410 bios password
To reset the BIOS password read the information from this
link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Output to tv
You'll need a cable that will connect from the computer to the tv. The
easiest way is if you get a cable that will have the same type of
connection for both the tv and the laptop. Otherwise you will need to
have an adapter that will go between the two.Once you have them
connected by a cable then turn the tv on and select the input (source)
which in most cases will be PC or Computer or HDMI etc. Boot the laptop
and the image should appear on the tv. If not you will have to Press
and Hold the FN function key near the bottom left on the keyboard then
hit the F1 thru F12 key that toggles the display. The correct F1 thru
F12 key to hit will have LCD/CRT on it or it will have the icon of a
display.
How to format a install windows xp3 on FUJITSU SIEMENS
backup your data first in any external source. insert bootable cd of xp and boot from it. follow the instruction and finish the installation after that install required drivers and apps.
in starting you need to select boot from cd., can be select-able from bios and also by pressing f12.
My power button is not working, is their any way to start the nootebook making a power shortcut?
If the laptop was opened up, (ALL power removed -> AC adapter and battery; PLUS -> anti-static precautions taken!), and the laptop has a power on switch, (under the power on button), that plugs into the motherboard; you can unplug the switch, and touch the motherboard contacts to try to turn the laptop on. (Sorry about the run-on sentence) Jump a wire or similar, across the contacts, and see if the laptop turns on. Could try to be more specific, and detailed, if you had listed more info about the Fujitsu Lifebook. Such as it's Series number and Model Number. Example: Fujitsu Lifebook E8210. In this example E is the Series number, and 8210 is the Model Number. Post back in a Comment.
Regards,
joecoolvette
How do I get into bios
As soon as the Fujitsu logo appears on the screen, press the F2 key. If this doesn't work, please post the specific family and model of your Fujitsu Siemens LifeBook PC.
Thanks,
Roger
How to download recovery disc
Recovery disc comes from the manufacturer and looks for the serial number of your computer. You would have to buy a recovery disc from the said manufacturer or just go buy a new operating system CD
Print screen button
GO TO CONTROL PANEL THEN FONT THEN TEX SERVISES AND INPUT LANG THEN CHOUSE WHAT YOU WONT
