mi unidad dice el cd esta vacio, no lee DVD, y no graba DVD es un multi dvd rewriter lg modelo...
(More)
mi unidad dice el cd esta vacio, no lee DVD, y no graba DVD es un multi dvd rewriter lg modelo gsa-h22n
I backed up all my files to a Sony DVD-R. The first couple of times I used the backup DVD-R on my...
(More)
I backed up all my files to a Sony DVD-R. The first couple of times I used the backup DVD-R on my new HP Pavilion (Vista) laptop, it worked great. The next time I inserted it, the DVD-R showed as blank. I used the DVD-R in another laptop (XP), the files were all there and okay.
HL-DT-ST DVD-RAM gsa-h22n I have the above driver. My computer sees the driver. It has it listed as...
(More)
HL-DT-ST DVD-RAM gsa-h22n I have the above driver. My computer sees the driver. It has it listed as a CD-ROM drive. The computer recognizes CDs but not DVDs.
It worked the first time I tried it, it read a cd, but ever since it's not worked. Is it a driver...
(More)
It worked the first time I tried it, it read a cd, but ever since it's not worked. Is it a driver problem and hardware problem or something else. The manufacting date is Feb 07 so does it stil have it's warranty and if yes how hard would it be to get it replace or repaired?
says: the cd is empty The dvd is empty in any case doesn´t read and the cd of configuration con...
(More)
says: the cd is empty The dvd is empty in any case doesn´t read and the cd of configuration con not read either
Hello This solution is for the following error codes 31, 32, 19, 39 and 41 shown in device manager in device status. If your cd or dvd drive isnt...
written by Ekse
If your DVD/CDROM is not working ie..playing movies or not installing programs it may be becuase you have installed a ssoftware program that edited...
written by ComputerDave
If the power goes or the drive refuse power up then follow this simple step to open it 1.) locate a small hole in the frount of the drive its about...
written by DARKLORD1
The Microsoft knowledge base which is located here : Website Link Walks you through step by step for both windows xp and windows vista how to delete...
written by the_fire
You Cannot
Put 700MB of Data on a 700MB RW Disc: Why?
(This
also pertains to DVDs and Solid State Flash Media)
[The
point of this Tip is to...
written by worldvet
Locate the pin hole in the drive picture from gateway web site Insert a straightened paper clip in this hole and push the drive will pop open, now...
by DARKLORD1
1.) set the jumper setting to the rear of the drive, master / slave ; cl,, 2.) put the prive in the system and secure it with screws This involves...
by DARKLORD1
We fix and repair laptop motherboard no video, no pow... Read More
We fix and repair laptop motherboard no video, no power, dc jack, lcd inverter, back light, shorted ac adapter issues down to component level. Cincinnati, Hamilton 45011, West Chester 45069, Fairfield 45246 Ohio OH Laptop PC Computer repair service, Projection bulb TV LCD, Plasma, HDTV, projector repair. Projection bulb TV, LCD TV, Plasma, project
Zkarlo.com provides discount and used laptop parts for... Read More
Zkarlo.com provides discount and used laptop parts for thousands of models. We offer Toshiba, Sony, HP, Compaq, eMachines & Gateway, Dell and more!
Choose from thousands of parts, including: LCD Screens, Motherboards, Keyboards, AC Power Supplies, Cases, Hinges, Drives, Batteries and more!
We connect to your computer over the Internet to qui... Read More
We connect to your computer over the Internet to quickly repair your PC. Call Toll Free (877) 729-0812 for a Free Quote. Professional support with certified techs to make your computer run like new again.
Send your laptop to us and we will diagnose the pro... Read More
Send your laptop to us and we will diagnose the problem free of charge! We repair all over the U.S.A.! Our master certified technicians will run tests to determine the problem and will call you with a quote within 48 hours! Our labor rates are low and very fair. We are proud to be an accredited Better Business Bureau Member with an A+ rating.
We offer computer consulting services, hardware and... Read More
We offer computer consulting services, hardware and software technical support. We specialize in networking design, installation, and support. No job is too big or too small. For the homeowner we offer a reduced rate. We also build our own pc?s and sell hardware and software
Affordable Laptop and Desktop Repair. We spe... Read More
Affordable Laptop and Desktop Repair. We specialize in Laptop LCD Screen repair, Laptop DC Jack Repairs, Laptop Motherboard repairs, Data Recovery. We offer on-site service, local walk in service where available and mail in services.
