20 Most Recent Yamaha CRW 8424 CD-RW Burner Questions & Answers
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Yamaha CRW 8424... | Answered on Mar 20, 2011
The drivers are part of the operating system. So make sure your operating system Is up to date or upgrade to the latest operating system Windows 10.
If the device does not work with Windows 10 then it's not worth keeping when hardware today is so cheap.
Yamaha CRW... | Answered on May 05, 2017
So to confirm he connected power directly to the battery springs?
What voltage did he connect to those springs?
If it was more than 12v you have almost certainly done some internal damage.
As best you may have blown a few diodes which are there to protect from small voltage overruns - at worst probably burnt out the motherboard.
If you do not know how to check these it is probably advisable to take to a repair centre.
Becketts Music
www.beckettsmusic.co.uk
Yamaha Computers... | Answered on Aug 23, 2019
So what are you getting? Power light, screen display, just no sound?
Try pressing a demo tune - does that work?
If it does then you may have a problem with the connector from keybed to motherboard.
If no sound just try connecting the disc drive up again - if this then makes it work it is probably hanging during the start up procedure.
Report back if you need to and we can try something else.
Becketts Music
yamaha dx100 reset. Press voice switches 1 and 2 while turning power switch on. Display will say test entry?. press the plus/yes button. This will reinitialize all memory to factory settings. Also the lithium ram backup battery voltage will be displayed as check level with a number representing the battery voltage. The number will be 10 times the actual battery voltage. A new battery will display 33 representing 3.3 volts. If your reading is below 22 then your battery is shot and will need replacing and if you turn the unit off it will probably get a scrambled memory again.
Yamaha Computers... | Answered on Jul 29, 2019
Guessing that some people think a Tyros 1 is a PC or something.
If the Tyros goes blank screen and all the lights go out then it is most likely the REG board (regulators) that provide the 5v and 3.3v. This overheats and the devices shutdown. Quite often this is cured with a restart on more serious cases the regulators need replacing. As they are cheep it is best to replace all while the unit is apart. I am just about to do this repair on a Tyros I purchased the other day.
Computers &... | Answered on Jul 27, 2019
AW4416 Users - HELP needed!
I think my hard drive crashed or is in trauma! It 'froze up' so I shut it down. When I try to restart it it never gets past the "Initializing the Recorder Section" window. The HD's red light is on without any intermittent blinking.
Is there a trick to get it to boot up so I can back some stuff up?
Last year when I had lots of stuff on the HD I had occasional freeze-ups but it always came back. Then when that project was finished I got all of it off the HD into a backup and the AW has been smooth for more than a year. Recorded a CD for a local string Quartet and everything was good. When that wrapped up I wiped the HD again and started a CD for myself. Not a lot of songs or tracks yet but some stuff I really don't want to lose if possible.
Hard lesson to learn.
Bill from PA, are you out there? any other AW4416 users?
the AW user forum (socialentropy.com) seems dead! I've gotten some great help there!
Thanks
Sourov
Yamaha Computers... | Answered on Jan 15, 2019
Mukhang ang iyong plug ay carbon fouled. Marahil ang iyong pinaghalong gasolina ay masyadong mayaman. Subukan ang pagsasaayos ng iyong karburator.
Yamaha Computers... | Answered on Nov 08, 2018
Yamaha CRW 8424 CD-RW Burner Logo
1 questions posted
Top Yamaha Computers & Internet Experts
Ekse
Marvin
Marvin
Harrie
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
CRW Yamaha
  • CRW Yamaha
Most Popular Question
nt4 0 when
  • Computers & Internet
