GE Americana A4425GDTWW Side by Side Refrigerator Logo
GE Americana A4425GDTWW Side by Side RefrigeratorTroubleshooting & Support
Problems & Solutions
  • I HAVE FOUND THAT THEY ARE INSIDE THE FRIDGE IN THE BACK. KINDA LOOKS LIKE A AUTOMOTIVE OIL FILTER.. NOT FUN BUT YOU WILL FIND IT THIS WAY.....
    • suzyk
    • May 27, 2011
    • 60 Views
    • 1 Solution
  • There are two possible causes or types of frosting. One is where the surface of the items in the freezer have frost on them. It may be in...
  • HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm...
  • You have a defrost system failure.  You can verify this by take off the rear shield of the freezer and looking at your evaporator...
  • Hi, I'm Leo This is a common defrost problem, The ice is not being melted by the defrost system. he fan can't blow into ref. Take...
    • fiskej
    • Jul 24, 2011
    • 13 Views
    • 1 Solution
  • Hello, Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils...
    • newric7
    • May 7, 2011
    • 25 Views
    • 1 Solution
  • can't you just remove the ice/water dispenser off the old doors and incorporate them into the new door instead of re vamping the...
  • Homework job for no water to the dispenser. After removing the grate at foot of refrigerator was able to get water to bottom of tube....
    • dlt1935
    • Dec 9, 2010
    • 58 Views
    • 1 Solution
  • Are you asking to adjust the temperature control board, or are you saying you just need a temperature control board?
  • This unit uses a dual water valve. One side for ICE one side for WATER. This is located in the back right hand corner behind the black...
  • Hi, Here is a tip that I wrote about the reasons why ice makers do not work. Ice Maker Problems and Ice Maker Troubleshooting heatman101 ...
  • Pulled out the bottom white tray that is under the wire shelving and at the back of the freezer is a small hole. Pour in a cap full of...
    • rtrbh
    • Sep 9, 2010
    • 25 Views
    • 1 Solution
  • Hi, Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling Refrigerator not...
  • Hi, As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser...
  • You can probably access the coils better from the back behind the cardboard cover. Make sure the fan near there is running when the...
See all GE Americana A4425GDTWW Side by Side Refrigerator Solutions
Tips & How Tos
Do you have any good tips or tricks? - Write a Tip!
More
Unsolved Problems
See all GE Americana A4425GDTWW Side by Side Refrigerator Problems
Manuals & Guides
Top
Do you have a manual for GE Americana A4425GDTWW Side by Side Refrigerator? - Upload it to FixYa!
Specifications
Top
Key Features
  • Full Product Name:
  • Number of Motors:
    1 Motor
  • Total Volume:
    25 cu. ft.
  • Fresh Food Volume:
    15.46 cu. ft.
  • Freezer Volume:
    9.56 cu. ft.
  • Ice Maker:
    With Ice Maker
  • Installation:
    Free-Standing
  • Total Number of Shelves:
  • Refrigerator Type:
    Side by Side
Fresh Food Compartment
  • Fresh Food Shelves / Bins:
    Gallon Storage
    Snack Drawer
    Dairy Center
  • Shelf Material:
    Wire
  • Door Opens:
    Opens to Left and Right
  • Light:
    Yes
Freezer Compartment
  • Shelve / Bins:
    Shelves x 3
  • Shelve / Bins:
    Bin x 1
Ice Maker
  • Dispenser:
    Water
  • Dispenser:
    Ice
Convenience
  • Exterior Color:
    White
  • Defrost:
    Automatic Defrost
  • Controls / Display:
    Electronic Control
Energy
  • Amperage Rating:
    15 Amp.
  • Annual Energy Consumption:
    715 kWHrs
Dimensions
  • Overall Depth:
    33.56 in.
  • Overall Height:
    69.75 in.
  • Overall Width:
    35.75 in.
Warranty
  • Warranty:
    1 Year Parts and Labor
What's your problem?
