20 Most Recent
Viking VCFF036 Bottom Freezer French Door Refrigerator Questions & Answers
One of the doors (on the Viking french door
Check with your Viking rep. I have the same problem and got word from Viking they are coming up with a new hinge doorstop at different angles. It will come in a form of a kit. The one I'm getting is about 100 degree opening. The problem I had was the door was hitting and adjacent electric oven from Viking. It just swung too wide.
How do you adjust the door swing angle on the
Check with your Viking rep. I had a problem that the door swings too wide. They said they are coming u with a kit to replace the door stop. I was told there will be a 100 degree doorstop kit for my problem The door when swung open gets a ding from an adjacent Viking electric oven with the professional door.
Refrigerator is too cold, and set on warmest
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Check out these tips...they can help you figure out whats going wrong with your
refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Refrigerator (VCFF136SSS3) internal temperature is
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Loud chatter from cold vent mechanism (
this is your damper control
it is a lil door that is being pushed ipen and closed
to regulate the temp in the refer, off the coils in the freezer,
yes you can remove the cover, some models have a screw, some just pull off,and snap on
some of these dampers creak, some dont
i know its annoying , but you may just get a replacement part that creaks too
hope this helps good luck
How can stains from stainless steel be removed
their are many products now for stainless steel from dollar shop wipes to $15 commercial all work great if ur stains are from fingerprints the cheep wipes work great for food like chicken or food dye disinfect or clean first than use ss wipes
