20 Most Recent
Migali Imperial R28ATH Commercial Refrigerator Questions & Answers
I have a migali fridge model#r28t. The handle is
either get some no more nails glue or some liquid metal and mix it up and follow the instructions on th pack...failing that you might be able to drill it and use pop rivets,you dont ned reare accessfor these.
What doe P1 error code mean on a Migali C-U27F Freezer?
In most every case, generally speaking, this code would indicate that the temp probe for the conditioned space has failed. Finding support for this proves to be difficult but in my 30+ years of refrigeration work, this almost always seems to be the issue. I would pursue this area first as the "P" usually means probe.
5/19/2019 3:29:19 AM •
Migali...
Answered
on May 19, 2019
I have an older Migali commercial reach in cooler. Label is worn . cannot get the model number. how can I identify for parts?
Generally all of the parts for the reach in coolers are generic. Best thing to do is bring the fan motor into the wholeslaler and match it up. If you need other parts just pull them out and match them up at the wholesaler. I don't remember the last time I was able to find an eom part. If it is a door gasket, you need to use the guide at the wholesaler and measure the length, they will make one up for you. If it is a compresser, there should be a model number on it the wholesaler can use, generally if it has a cold pack on it it will be a AEA4440YXA or AEA4430YXA.
Good luck
9/6/2012 2:11:56 PM •
Migali...
Answered
on Sep 06, 2012
