20 Most Recent magicJack PLUS VOIP Phone Adapter Questions & Answers
I get message "error1 check connection or go to msgicJack.com is wrongwhat All is hooked, the bill is paid and
You most likely need to update the software on you unit. Download and install this file: "upgr980.exe" a Google search should find it.
1/18/2015 7:44:12 AM • magicJack PLUS... • Answered on Jan 18, 2015
2answers
How do I renew my Magic Jack service?
Just go to the website and log in with your phone number and password. IF you have not yet signed up on the website do that and then you can renew your service from there. https://web03.magicjack.com/my/index.html?myfocus=locInfo
1/7/2015 11:53:29 AM • magicJack PLUS... • Answered on Jan 07, 2015
2answers
My magic jack plus will not work and I am wondering if the electrical connector is bad.
Go to the magic jack website and update your adapter. Also try different USB ports and reboot your computer with magic jack connected. If the computer does not recognize the adapter, try disconnectin and reconnecting into different ports. There is a update option on magic jack website and tech support as well.
12/25/2014 11:20:27 PM • magicJack PLUS... • Answered on Dec 25, 2014
2answers
How do i retrieve my PIN no.
If you enter the PIN and it is wrong 3 times, then the phone will ask for a PUK (PIN Unlock) code. This will be printed on your SIM card holder. You have 10 chances to enter this correctly, then you will be able to enter a new PIN. If you don't have your PUK then I'm afraid your stuffed. Well, actually that's not quite true. You can go to you're network's phone shop and ask them for a duplicate SIM. In my country this will cost anything between 5 euros and free. This will come with a shiney new PIN number. The only downside is that phone numbers stored on your old SIM aren't accessible.
12/14/2014 1:30:05 PM • magicJack PLUS... • Answered on Dec 14, 2014
I have magicjack plus.My phone is not working for 5 days. It says There is a system error". I checked all my connections.This a 6times since Jan.2014.
did you make sure to install the drivers on your 'prime' computer? you have to configure using a computer for the system to function.
11/29/2014 6:33:59 PM • magicJack PLUS... • Answered on Nov 29, 2014
Will buying a new connecter fix the problem?
These things are made cheap and will eventually go bad. I'd replace the whole unit. I quit using mine when I found it cost me no more for long distance calls on my land line and have to have a land line to get my DSL for computer. Just been in my desk drawer for the past 7 years.
11/15/2014 6:39:00 PM • magicJack PLUS... • Answered on Nov 15, 2014
I got a message on my phone that says my Magicjack has expired .....what is my next option ?
need to get and update on it, need to pay it
10/22/2014 2:02:26 AM • magicJack PLUS... • Answered on Oct 22, 2014
How do I RENEW MY PHONE NUMBER ?
if its a cell phone go onto your network and there you will find the answer
10/5/2014 5:13:17 PM • magicJack PLUS... • Answered on Oct 05, 2014
Why am i experiencing clicking sound on all incoming calls?
Some phones give you a beep our click at specified intervals too let you know how many minutes you are using.I suggest checking your call timer settings as this can usually be turned off.
9/4/2014 3:05:33 PM • magicJack PLUS... • Answered on Sep 04, 2014
Macintosh MagicJack Plus software application download please
unplug your magic jack and reinstall it into the computer. the software should load
7/3/2014 12:15:53 AM • magicJack PLUS... • Answered on Jul 03, 2014
Can't be heard by party i dialed but they can hear me on a mj dongle in windows 7,,had service for a couple of years..use boomed headset plugged into a Lenovo Y560 3.5mm ports...problem startesd yeste
CHECK SETTING IN SOUND OPTIONS AND CHECK ANY PORT IF ARE ASIGNED TO OUT PUT OR INPUT OR TRY REINSTALL YOUR SOUD DRIVER OR UPDATE.
12/17/2013 2:43:12 PM • magicJack PLUS... • Answered on Dec 17, 2013
My laptop window 7 OS wont recognize my magicjack plus. what will i do?
make sure its updated?try running it as administrator your firewall or anti virus IP maybe blocking it check all three to see if IP is blocking it use the USB port if it dosn't work trough that your IP is blocking it try reinstalling it follow instruction don't just click next read what it says. it may ask do you want to run as adminnistrator
10/27/2012 10:53:01 PM • magicJack PLUS... • Answered on Oct 27, 2012
I had a paper jam in this model: DM72C and I cleaned all the paper out but it won't start shredding again even though all the power lights are on and ready. What am I missing?
You were asked questions? I have been campaigning for this for 3 months. I told them you need a pop-up All questions need 'make model (what it is)' as first 3 words. You are missing the maker, but you do mention 'shredding'. Then I also said 'There are 40,000 categories to choose from'. You chose 'Cell Phones'. and it's not a 'memo', it's a question. :>) So, first of all, disconnect it from the mains for 30 minutes. If you jammed it, you were working it hard, and when it jams, heat builds up in the motor and trips the thermal protection device. They have a thermal cut out, some have a thermal fuse what need physically replacing, but most reset when they cool. Does it work in reverse? A jam can sometimes damage the switch in the throat of the shredder, some are a mechanical switch, some are an infra-red sensor. https://www.google.com/search?q=DM72C ..
4/24/2024 12:12:23 AM • Cell Phones • Answered 2 hours ago
4answers
HOW TO GET A PIN CODE IN RAN ONLINE PH
how to retrieve my pin code in ran online
4/23/2024 5:38:00 AM • Cell Phones • Answered 20 hours ago
2answers
What is the difference between CEH V8 and CEH V9?
The difference between EC-Council's Certified Ethical Hacker v8 and the new Certified Ethical Hacker v9 is not the exam format, but the content itself. People seem to assume that since EC-Council updated the certification, the exam must be brand new. This isn't the case. In order to obtain the new CEH v9 certification, you do not need to study for and pass a brand new exam with new objectives and format. The test has the same format, is identical in size, and has the same amount of questions. There are only two things that changed. CEH V9 EXAM FORMAT AND BREAKDOWN The aforementioned v9 exam follows the same format and percentage breakdown of questions as v8. For example, the section on security will still take up 25% of the exam, while the section on tools, systems and programs will take up 32% of the exam. The full breakdown of the exam is visible on our . The Exam Details are as follows:125 questionsTo pass you need a score of 70%Maximum of a 4 hour durationMultiple choice formatHOW TO PASS YOUR CEH EXAM If you are studying v8 exam materials, you are not automatically going to fail the v9 exam. The test is updated, not revamped. This means there might be a handful of questions you may not necessarily have studied in depth for, but if you studied at all, you will have some familiarity with the new questions. The new questions are not on brand new material, they are more in-depth questions on topics that have become more relevant in the cyber security world over the last eighteen months. So you can still pass v9 studying v8 material.Should I still take CEH v8 Exam? However, if you study v8 materials you can still take the v8 exam. EC-Council has not retired the exam yet. So if you are not comfortable with the idea of taking an exam that you may not know 10-15 "new" questions, then don't. The only problem with this is that once the v8 certification does retire you will eventually need to take v9. Why prolong the inevitable then?Will I need to take the CEH v9 exam? If yes, then when? The test is updated on a rolling basis. This means that occasionally EC-Council adds new questions to the exam without updating the entire certification. The fact that v9 is now available means that there are new and updated CEHv9 study materials with a new focal point to deal with the always progressing world of IT.THE DIFFERENCE BETWEEN CEH V8 AND V9 With the update to the courseware, the exam covers certain questions differently. These questions focus on topics that are becoming more prevalent in the world of cyber security and IT. The key differences are:V9 focuses on cloud computing more than v8 did and dives into best security practices for dealing with cloud computing attacks.V9 covers mobile security and tablet computers and you must understand how to perform hacking techniques on these devices.v9 addresses new vulnerabilities in cyber security such as, Heartbleed, Shellshock, and POODLE. CEH v9 vs v8 What New on the Certification Exam TechRoots
4/22/2024 6:43:13 AM • Cell Phones • Answered Yesterday
I'd like to update my stereo in my Citreon C3 (2007) to a double din header unit.
Let's explore your options: Double DIN Stereo Upgrade Kits: There are aftermarket double DIN stereo upgrade kits available specifically for Citroen C3 (2010-2016) and Citroen DS3 (2010-2019) models. These kits include everything you need for a seamless installation, including a fascia kit, plastic brackets, screws, blanking buttons, steering wheel control interface, antenna adapter, USB and AUX retention leads, and a universal patch lead. The installation process involves removing the original single DIN radio, fitting the new plastic frame and fascia around the double DIN radio, and connecting the wiring harness and other components. These kits are designed to retain steering wheel audio controls and other features. Keep in mind that dashboard modifications are required, so professional installation is recommended. Connects2 Adapters: If you choose an aftermarket stereo that isn't specifically designed for your Citroen C3, you can use a Connects2-style adapter to convert a compatible aftermarket stereo to control the screen above the radio (date/time, etc.) 3. This way, you can still access essential information. For example, a Double DIN Android Auto-compatible stereo like the JVC KW-M560BT could fit in the space after removing the cubby and factory radio. Some C3 models have a dash-mounted CD autochanger or other features that need careful handling during the upgrade. Citroen C3 2009 Aftermarket radio upgrade - Double DIN (citroenc3owners.com) Professional Installation: Consult with a car audio installer or technician to choose the best solution for your specific Citroen C3 model. Regardless of the approach you take, professional installation is highly recommended.
4/20/2024 10:12:16 PM • Cell Phones • Answered 3 days ago
Kyocera DIGNO Dual WX04K. HOW TO RESET KYOCERA WX04K DUAL DIGNO please?
How to hard reset KYOCERA DIGNO WX04K WILLCOM
GSM Hosting https://forum.gsmhosting.com > vbb > how-hard-reset... Feb 24, 2016 - Ihave solution turn off mobile than holde both volume keys and connect usb i will install adb drivers and than install kingoroot in pc and ... Missing: DUAL ‎' Show results with: DUAL
How To Do A Hard Reset On Kyocera DIGNO Dual WX04K
Tweakdroid https://tweakdroid.com > hard-reset > kyocera-digno-d... Nov 28, 2021 - To start, go to the Settings menu of your Kyocera DIGNO Dual WX04K; Find the factory data reset option. · Click on Erase all data. ; Turn off the ... ..
4/20/2024 7:30:08 PM • Cell Phones • Answered 3 days ago
magicJack PLUS VOIP Phone Adapter Logo
39 questions posted
Top magicJack Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a magicJack Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • magicJack Cell Phones
Most Popular Question
renew magic jack service
  • Cell Phones
