20 Most Recent Kolpak (SK8-1328-CI) Commercial Refrigerator Questions & Answers
if you found smell [ which cant be smelled online ] clean source so it doesnt smell any more and then no headaches and as to toxic that is also unknown
Kolpak... | Answered on Jun 08, 2017
Suggest replace the element.
Since this is an electrical/safety issue also suggest have qualified personnel attend to it.
Kolpak... | Answered on Nov 02, 2017
The most likely causes are an evaporator fan not working or a defrost system failure. If there’s a layer of frost building up on the back wall of your freezer then you have a defrost problem and not enough cold air can get to the fresh food section. I would recommend getting a professional out to fix it. If you want to try to fix it yourself, look up “LG fridge not defrosting”.
Refrigerators | Answered 5 hours ago
If leaking from the back and outside of the box, you need to tighten the water line. If it is leaking water from inside the box , bottom front then you need to defrost the fridge and after you defrosted check that the fan or fans are operating when it's on and no more ice is left.
Refrigerators | Answered 21 hours ago
adjustment on this mystery item is always done at the hinges, slacken them off a little and move the door to how you want it and then tighten them back up.
Refrigerators | Answered 2 days ago
You need gauges to check the freon charge while it's short cycling, could be restricted or low on charge! You might try cleaning the coils and see if it's an air restriction, you have a safety device causing it to shut down and most the time on those its bc they are interchanged!
check the parts number see whether same or not.
Check to see if there is ice/frost in the air passage between the freezer and the refrigerator. If warm humid air gets in, like leaving the door open too long or opening it too often, the passage can get blocked and cold air can't get to the refrigerator. The controls for setting the temperature often include one to open or close that passage and so will help you locate it. A heat gun or hairdryer can help melt the ice. Also, check to make sure you have not blocked the flow of air at either end.
Kolpak (SK8-1328-CI) Commercial Refrigerator Logo
7 questions posted
Top Kolpak Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you a Kolpak Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kolpak Refrigerators
Most Popular Question
days now
  • Refrigerators
