20 Most Recent Kenmore Elite White 1.5 Cu. Ft. Convection Microwave Oven 67902 Questions & Answers
Most microwaves just need to have the clock button pressed 1 time. Then you enter the time. Next some want to to pick am or pm. Then press clock again to set. Sometime last step is the start button instead of clock.
Kenmore Elite... | Answered on Mar 02, 2015
Pretty sure the capacitor is bad and it is time to get a new microwave.
Kenmore... | Answered 3 days ago
Deanna:
There is a door sensor in the door frame of your microwave that tells the microwave if the door is open or shut. That sensor is not working for some reason. The sensor is near the latch mechanism and is made of plastic and has probably broken and needs to be replaced. I would take it to a small appliance repair shop. Microwaves are nothing to fool with if you do not know what you are doing.
Kenmore... | Answered on Sep 15, 2019
Check Latest News, Recruitment, Notification, Admit Card, Result at jobs4u Find Jobs Check Result
Kenmore... | Answered on Sep 13, 2019
I suppose it is possible you pressed the wrong button - if you disconnect it from the power for a few minutes it should cancel whatever action you might have taken, though realistically it is more likely your microwave has developed a fault that is best tackled by the repair shop.
Kenmore... | Answered on Jul 04, 2019
There are parts inside the unit that fail and can cause this. One such part is the high voltage diode. You can repair it yourself but if you dont know electronics, I dont recommend it.
Kenmore... | Answered on Jun 30, 2019
Unplug the unit for 5 minutes then plug back in. If that doesn't work, contact an authorized technician. Danger, High voltage inside.
Kenmore... | Answered on Jun 20, 2019
Unplug it for 5 minutes then plug back in. No luck? Contact an authorized technician. Danger, high voltage inside
Enter your make and model no. On www.repairclinic.com for information and parts, wiring, diagnostics
I DON'T KNOW. BE VERY CAREFUL AROUND MICROWAVES DUE TO HIGH VOLTAGES AND RADIATION
ALWAYS UNPLUG IT BEFORE SERVICING THEM. YOUR
SYMPTOMS SUGGEST THE DOOR SWITCH NEEDS TO BE REINSTALLED OR REPLACED. IT SEEMS IT IS IN THE 'OPEN DOOR' POSITION. . I RECENTLY REPAIRED ONE. I UNPLUGGED IT AND REMOVED THE OUTER SHELL. I COULD SEE THE VARIOUS OFF/ON SWITCHES AND THEY JUST SNAPPED INTO PLACE INTO PLASTIC HOLDERS. I USED IDENTICAL SWITCHES FROM OLDE THROW AWAY MICROWAVE.OF A DIFFERENT BRAND,
TO MY SURPRISE, THEY BOTH USED SAME SWITCHES.
Kenmore... | Answered on May 22, 2019
REMOVE THE ENTIRE OUTER CASE
Kenmore... | Answered on May 19, 2019
Kenmore Elite White 1.5 Cu. Ft. Convection Microwave Oven 67902 Logo
1 questions posted
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Microwave Ovens
Most Popular Question
clock will not set time
  • Microwave Ovens
