20 Most Recent
Husqvarna Rz5424 Zero Turn Lawn Mower Kohler Courage Engine Questions & Answers
I have a Husqvarna RZ5424 and when I was mowing
I just solved my problem with mower was completely dead. The wiring harness runs under the battery above the rotating pulleys for the mower deck. Must have been a branch or something got caught and severed through one wire completely and partially through the others. I spliced and taped everything and it works for now. Poor engineering in my opinion. May have to get new wiring harness at some point. They run about 64$ on amazin
Why is my husqvarna zero turn leaving a strip of uncut grass on the left side of the deck
I have a 2014 HUSQVARNA RZ5424 that I just changed the blades on for the first time now 2017. I got new gator blades because of all the good reviews on them. They are about as good as a screen door on a submarine at 300 feet deep. There the same length as the original blades but leaves two rows of uncut grass about a inch wide regardless of how you try to cut it. Only 240 hours on mower, deck clean ,spindles kept greased . Went back to new Husquvarna blades like the ones made for it. PROBLEM SOLVED. HAPPY HAPPY HAPPY. REL.
After cutting grass i parked it to open the gate. I got up and it backfired. now all it will do is spin over.any clue?
In my younger day if you did not idle down and cool off before shutting off the switch it would backfire and break the connecting rod. Carbon builds up on the head and glows red from heat, when you got up the safety switch for the seat shut it off . The red hot carbon on the head lit the fuel with the piston in who knows what position. If you can remove the spark plug and put your thumb over the spark plug hole and crank it over, should be compression and blow some air around your thumb. You might of got luck and blowed out the head gasket, check that out and come back.
