20 Most Recent Minka Aire Ceiling Fan Questions & Answers
Maybew the fans wireless can be programmed for a different channel or lower power/signal.
Have you checked with thier
Customer Care Department hours:
Monday - Friday 6:00 a.m. - 5:00 p.m. PST
Toll Free: 1 (800) 221-7977
Minka Aire... | Answered on Jul 12, 2016
OKAY I HAVE A POSSIBLE SOLUTION! THERE SHOULD BE A GREEN LIGHT AT THE TOP OF THE REMOTE AND A BLUE LIGHT AT THE BOTTOM. YOU NEED TO TURN OFF THE BOTTOM SWITCH, WHERE THE BLUE LIGHT IS, FOR 5 SECONDS THEN BACK ON. THEN HOLD THE CENTER STOP BUTTON FOR 5 SECONDS AS WELL. THIS WILL ALLOW FAN AND REMOTE TO RESYNCHRONIZE, IF BLUE AND GREEN LIGHTS BLINK TWICE THEN U HAVE SUCCESSFULLY RESET BOTH FAN AND REMOTE. IF THIS DOESN'T WORK CALL MINKA AIRE TECH SUPPORT 1-800-221-7977. GOOD LUCK!
Minka Aire... | Answered on Apr 21, 2016
Call Minka Aire at 1-800-307-3267
Minka Aire... | Answered on Feb 04, 2016
Your Minka Aire is also available on AMAZON...
The trouble you are describing involves YOUR control module INSIDE your fan body... I had a SIMILAR TROUBLE on a CASA BLANCA... had to replace the CONTROL MODULE myself... but for the 13 foot ceiling... and needing to ALSO upgrade the WALL SWITCH (Intelli Touch W32 Wall Control) to match... It was an EASY JOB.
Remember to ground out your hands before touching delicate electronic equipment (or an anti static wrist strap)...!!
Also remember... the REAL PROFESSIONALS always remove power (when possible).
Be SAFE.
To VERIFY, Technical Assistance... and get PARTS
Check out the links below or call:
Fan Man Lighting
15465 Cedar Ave S
Apple Valley MN 55124
(952) 898-2754 local
(866) 600-FANS (3267) toll free
Hours of Operation (Central Time)
Monday - Thursday
10:00 - 7:00
Friday 10:00 to 5:00
Saturday 10:00 to 5:00
Sunday 12:00 to 5:00
Fan Man Ceiling Fans and Lighting
Your search returned the following results
Fan Troubleshooting
Minka Aire... | Answered on Jan 26, 2016
Push up on the glass all around to loosen it (be careful not to break). You could also spray a little WD-40 around the top of the glass. If these don't work, you might have to break the glass. Call Minka Aire @ 1-800-307-3267 and let them know the problem and they might send a replacement at no-cost.
Minka Aire... | Answered on Jan 04, 2016
Call Minka @ 1-800-307-3267
Minka Aire... | Answered on Nov 03, 2015
If it had a wall remote you probably need to use that. You could have a bad receiver. If it doesn't have a light, you need a TWO-fan control. A regular fan control is for 1 fan only.
Minka Aire... | Answered on Aug 25, 2015
There's either screws on the bottom or sides.
Minka Aire... | Answered on Jul 06, 2015
First, what is the fan brand & model. Normally small dip switches are on fan top
Minka Aire... | Answered on Jul 02, 2015
If it has a remote, press down on the light button and keep it pressed down until your light gets to full brightness.
Minka Aire... | Answered on Apr 27, 2015
There is no way to reset the dip switches without getting into the motor housing. Unfortunately you will have to dismount the fan.
Minka Aire... | Answered on Apr 25, 2015
Yes you can replace the receiver only. Just be sure you set the new one to the same frequency as your existing remote and all will be well!
Minka Aire... | Answered on Feb 13, 2015
Minka Aire Ceiling Fan Logo
139 questions posted
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Marvin
Marvin
Are you a Minka Dryer Expert? Answer questions, earn points and help others
View Most Popular
Minka Dryers
  • Minka Dryers
Most Popular Question
2 same ceiling fan up down in house
  • Dryers
