20 Most Recent
Whirlpool DU805DWG Dishwasher Questions & Answers
Pre-rinsed dishes come out with food residue as if
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
Dishwasher
Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
2/27/2011 10:58:24 PM •
Whirlpool...
Answered
on Feb 27, 2011
Wonderful Whirlpool Washus Interuptus!
My plan was to see if I could find you a service manual, but strangely, the only reference to that model number is your post here! My guess is the D6 is 'D for Dishwasher' and 'Series 6' or 6 models in that current series.
If the machine has been laid up or little used, check all the connection on the control board. Clean pins and plugs with electrical switch cleaner
https://www.google.com/search?q=DU940QWD6
8/26/2023 5:52:50 PM •
Whirlpool...
Answered
on Aug 26, 2023
How would I get access to whirlpool dishwasher pump?
Miniplayer (i)
We'll also want to shut off the inlet watersupply and disconnect that as well.
0:30/8:42
Please refer to youtube " Whirlpool Dishwasher Repair - How to Replace the Pump (Whirlpool # W11032770) "
3/23/2023 7:01:32 PM •
Whirlpool...
Answered
on Mar 23, 2023
My whirlpool dishwasher model # WDT780SAEM1 makes a loud popping noise when I open and shut the door. What is causing it and how do I fix it?
The loud popping noise that you're hearing when you open and shut the door of your Whirlpool dishwasher (model # WDT780SAEM1) is most likely caused by the door gasket. The door gasket is the rubber seal that runs around the door, creating a tight seal when the door is closed.
Here are a few things you can try to fix the issue:
- Check the gasket for damage: Inspect the door gasket for any tears, cracks, or other damage. If you find any damage, you will need to replace the gasket.
- Clean the gasket: Over time, debris and food particles can accumulate on the gasket, causing it to become stiff and not seal properly. Clean the gasket with a mild detergent and warm water, and then dry it thoroughly.
- Check the door alignment: Make sure that the door is properly aligned and not hitting the gasket when you open and shut it. If the door is not aligned properly, you will need to adjust it.
- Lubricate the hinge: If the door gasket is in good condition and properly aligned, the problem may be with the hinge. Try lubricating the hinge with a silicone-based lubricant, as this can help to reduce friction and noise.
- Contact Whirlpool: If you have tried all of the above steps and are still unable to fix the issue, contact Whirlpool customer service for further assistance. They will be able to provide you with additional troubleshooting steps or advice, or they may need to send a technician to repair or replace the dishwasher.
It's important to note that if the popping noise you're hearing is accompanied by other symptoms, such as leaks, then it may be related to a different problem, and you should contact Whirlpool customer service or a professional service technician for further diagnosis and repair.
1/14/2023 1:48:41 AM •
Whirlpool...
Answered
on Jan 14, 2023
Whirlpool gold quiet partner iii soak and scour indicator light on won't start
Es posible que la luz Soak & Clean del lavavajillas Whirlpool Gold Quiet Partner III no se encienda si el lavavajillas no est? recibiendo energ?a o si el lavavajillas no est? en el ciclo correcto. Se recomienda verificar la fuente de alimentaci?n y asegurarse de que el lavavajillas est? enchufado y reciba energ?a. Si la alimentaci?n est? conectada y el lavavajillas est? en el ciclo correcto, entonces es posible que haya un problema con los circuitos o el cableado del lavavajillas. Se recomienda ponerse en contacto con un centro de servicio autorizado de Whirlpool para obtener m?s ayuda.
1/6/2023 2:20:04 AM •
Whirlpool...
Answered
on Jan 06, 2023
Updated question - What would cause a Whirlpool Dishwasher DU1148XTPB3 Soap Dispenser's trigger/spring to continuously try to open the soap dispenser after it has been opened.
here are a few possible causes for a dishwasher soap dispenser's trigger/spring to continuously try to open the dispenser after it has been opened:
The trigger/spring mechanism may be damaged or broken. This could be caused by normal wear and tear over time, or it could be the result of a foreign object getting stuck in the mechanism.
The dishwasher's control board may be malfunctioning. If the control board is not functioning properly, it could send a signal to the soap dispenser to continuously open and close.
There may be a problem with the dishwasher's timer or motor. If the timer or motor is not working properly, it could cause the soap dispenser to malfunction.
To troubleshoot the problem, you could try cleaning the soap dispenser and checking for any foreign objects that may be stuck in the mechanism. You could also try resetting the dishwasher by turning off the power and unplugging it for a few minutes, then plugging it back in and turning it on. If these steps do not resolve the issue, it may be necessary to call a professional for further assistance or to consider replacing the soap dispenser.
12/29/2022 3:12:20 PM •
Whirlpool...
Answered
on Dec 29, 2022
