20 Most Recent HP Officejet J5780 All-In-One Printer Questions & Answers
Open the "Control Panel" on your PC then open the Printer List. Right click on the printer you want to remove and click remove device.
HP Officejet... | Answered on Mar 03, 2015
www.lbrty.com. They have many manuals and diagrams.
HP Officejet... | Answered on Jun 06, 2014
Have you checked the spring is fitted correctly?
HP Officejet... | Answered on Jan 28, 2014
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
HP Officejet... | Answered on Jun 03, 2013
try to check ebay.com
HP Officejet... | Answered on Mar 22, 2013
Sounds like the refilled cartridge chip is not good, take back to where it was filled and get another cartridge
HP Officejet... | Answered on Feb 09, 2013
Yes it will not work unless you can reset the chip.
This WEB site can assist you in resetting the chip in the cartridge.
http://www.misterinkjet.com/hpreset.htm
HP Officejet... | Answered on May 21, 2012
First off all check, printer printing properly?, if its printing only scan option not functioning then uninstall the drivers and re install once again. If printer is not at all printing, check system recognizing the printer or not.. if not recognizing, check with another USB cable,Replace formatter...
HP Officejet... | Answered on Feb 02, 2012
Hi Cathy, Unfortunately I am not familiar with the J5780 machine. Sorry I could not help. Kind regards Printdesigns
HP Officejet... | Answered on Dec 01, 2011
If the HP WEB site does not have a printer driver for the version of Windows that is installed on your computer then either the printer is too old or not compatible for that version of Windows then HP would like you to upgrade your printer to a new model printer.
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
HP Officejet... | Answered on Aug 07, 2011
Hello.
On the front of the cartridge are some gold coloured dots, these dots line up with pins inside the printers cartridge holder. Make sure all these pins are lining up and free of any ink or dirt. Use a bright torch to make it easier.
I hope this helps Regards GM
HP Officejet... | Answered on Jul 15, 2011
If the phone line is attached to the unit, you may hear the fax line ring because as I recall, that circuit is powered by the phone line, but it will not answer or receive a fax while it's not plugged into the power outlet.
If that's not what you meant, please clarify and I will attempt to further help you.
HP Officejet... | Answered on Mar 18, 2011
go to tools and settings of your printer and you will the ink levels
HP Officejet... | Answered on Jan 09, 2011
this is the link to download your HP Printer Driver http://download.famouswhy.com/hp_officejet_j5780_all-in-one_driver/
HP Officejet... | Answered on Dec 21, 2010
The remote machine appears to be locked.
Solutions
  • Ask the user of the remote machine to turn it off for 10 seconds, and then turn it back on. Retry the transmission.
  • Send to another fax machine to make sure the issue is with the one specific remote machine.
If you need more help come back.Post / thumbs / testimonial are welcome!
HP Officejet... | Answered on Nov 28, 2010
Download the manual from HP website http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=au&lc=en&dlc=en&document=&product=3301296
Page 127 covers clearing paper jams.
HP Officejet... | Answered on Nov 18, 2010
HP Officejet J5780 All-In-One Printer Logo
Popular Tags
74 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
refill officejet j5780
  • Office Equipment & Supplies
