20 Most Recent
Hobart 2-deck Electric Baking Roast Pizza Oven With Stones Hcn50 Questions & Answers
How do I clean a
This happened to me:I used a gel rust remover with an electric pad sander (3 times - with a medium course paper the first 2 times, and then a finer course paper the 3rd time). It smoothed and cleaned it up pretty darn good, but there was still a slight red discoloration to the metal. So, we just kind of line the hopper with heavy duty aluminum foil and line over that with 2 clean plastic food grade bags. Also, now as part of maintenance/cleaning after use, we use a little spray rust remover at the beginning of the cleaning process. This should help prevent any more rust and might even help dull that red discoloration after a while.Good luck.
I have a hobart comercial convection oven. The
The oven has a 3 try electronic spark control. It sounds like the flame sensor is not sensing the flame correctly and is locking out. I don't know if your model senses flame through the high voltage spark wire or if it has a separate flame sensor wire.
Model2912slicers indexknob locked after we
what position is the gauge plate in when you removed the index knob? When you try to adjust the gauge plate is the carriage all the way towards the operator? the carraige has to be in the home position. Are you able to switch the operation of the unit from manual to automatic? All these steps are discussed in the manual for your machine as well if you dont have your manual click this link
http://www.wasserstrom.com/wcsstore/ExtendedSitesCatalogAssetStore/Attachment/492246manual.pdf
I would try seating the carriage towards the home postion and switch the unit from automatic to manual as long as you are assured that you did reinstall the index knob properly if you did not remove the screw for the knob and reinstall. If you have any further questions message me back I await your reply to the questions that I asked Thanks
Rick
