Quorahttps://www.quora.com > What-does-CL-mean-on-a-dish...
This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ...
9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
JustAnswerhttps://www.justanswer.com > Appliance Repair
Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone.
1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your
..https://www.youtube.com/watch?v=Xr4DBwACUW4
Dishwashers come in standard sizes. Your old one is 60 CM wide and made for built in.
https://www.bosch-home.ca/en/supportdetail/product/SGU4025AU/31
DISHWASHER 60 CM BUILT-IN/BUILT-UNDERSGU4025AU/31
As long as the new one is also for built in, the dishwasher will fit. Measure the height of the space you have. There may be a little height adjustment on the feet.
AI Bot Answer Deleted.
In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling.
An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
Check if there is anything in the large item trap or blocking the water level sensor. The dishwasher won't try to fill if it believes it is full. Try pressing and holding the Start button for 3+ seconds. The Clean LED should light up in a minute. If it does, try the on/off button and starting a new cycle. (This just clears any old programs from the memory.) Some washers will stop if they detected a water leak. Sometimes turning off the power for a while and checking for water in the cabinet below the dishwasher or in the motor area is useful.
The more likely items to check: Check the wiring between the inlet valve and the control board. Check the wires for corrosion at the connecting pins and for continuity. Broken conductors don't send a signal to open and close the valve. If those are okay, then the control board itself may be faulty.
Since this dishwasher is discontinued by the manufacturer, I don't know if all of the parts are still available. The only parts list for the SHE3ARL2UC/28 that I found is here: https://www.partselect.com/Models/SHE3ARL2UC/ . They don't list any wires or the control board.
I hope this helps.
If you're seeing an E3 error on your Bosch built-in microwave, it usually indicates an issue with the touchpad or control board. Here are some steps you can take to try to fix the problem:
1. Unplug the microwave: The first step is to unplug the microwave from the electrical outlet for at least a minute. This will reset the control board and may clear the error code.
2. Check the touchpad: Sometimes, the E3 error can be caused by a stuck or malfunctioning touchpad. Check the touchpad for any damage or debris that may be interfering with its operation. Clean the touchpad with a soft, damp cloth and make sure it is completely dry before plugging the microwave back in.
3. Replace the touchpad: If the touchpad is damaged or not working properly, it may need to be replaced. Contact a Bosch authorized service center to order a replacement touchpad and have it installed by a qualified technician.
4. Replace the control board: If the touchpad is not the issue, the E3 error may be caused by a faulty control board. Again, contact a Bosch authorized service center to order a replacement control board and have it installed by a qualified technician.
In any case, if these solutions do not work, it's best to contact a qualified technician to diagnose and repair the issue, as microwave repairs can be dangerous due to the high voltage involved.
I had this exact problem. There is a single hole on the underside of the arm, and it seems like the jet from it is enough to lift the arm so that it clears the plastic. The hole was clogged for me. Still have some thumping noise but it's 1/10th of what it was before.
Jul 5, 2021 - What have you tried so far? When I try to start the cycle, the red light on the floor comes on, it beeps, but won't start.
1 answer · Top answer: Hi and welcome to Justanswer. My name is ***** ***** to assist you today. I'm
Why is my Bosch dishwasher beeping and not starting?
Bosch dishwashers are designed to beep when there is an error. A beep means that your drain is not clogged, and the rest of the parts are functioning as they should. Beeping in the middle of the cycle points to the problem with the control board itself. Find the circuit breaker and turn it off for 60 seconds.
