FixYa.com
IBM NetVista M42 PC Desktop
All Products > IBM > PC Desktops
Problems with IBM NetVista M42 PC Desktop?
Troubleshooting and Support
Solved Problems for IBM NetVista M42 PC Desktop RSS Feed Post a New Problem
!! Help !! Problem with IBM Audio...
        I have an Audio Capture/A card installed in my PS/2 which is running      ...
3 Solutions
video driver
I need a video driver for IBM 8305 25u integrated video
2 Solutions
i have same problem as ninja9er
have an ibm netvista 8307 trying to upgrade to 2GB (2x1GB modules) have tried both PC2700 333 and PC2100 266 DDR but...
1 Solution
NetVista M42 8305 mobo jumpers & pins...
My mobo is out of its original tower. I want to use a standard tower for it, but don't have a clue how to do. Could you...
2 Solutions
Jumper settings on 8307-48U mainboard
Doesn't IBM have documentation on jumper settings for service techs? If this is the case, none of my customers will...
1 Solution
memory upgrade
I have an ibm netvista 8307 trying to upgrade to 2GB (2x1GB modules) have tried both PC2700 333 and PC2100 266 DDR but...
1 Solution
how to validate manuals
i need toknow how to validate a manual
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Operating SystemMicrosoft Windows XP Home Edition · Microsoft Windows XP Professional · IBM OS/2 · PC DOS · Microsoft Windows 2000 · Microsoft Windows 2000 Professional
Form FactorTower · Micro Tower · Small Form Factor · Desktop
ProcessorIntel Pentium 4 2.53 GHz · Intel Pentium 4 1.8 GHz · Intel Pentium 4 2 GHz · Intel Celeron 1.7 GHz · Intel Pentium 4 2.4 GHz · Intel Pentium 4 1.7 GHz · Intel Pentium 4 2.66 GHz · Intel Pentium 4 2.8 GHz · Intel Pentium 4 3.06 GHz · Intel Pentium 4 2.26 GHz · Intel Celeron 1.8 GHz · Intel Celeron 2 GHz · Intel Celeron 2.1 GHz
Installed Memory256 MB (DDR SDRAM) · 512 MB (DDR SDRAM) · 128 MB (DDR SDRAM)
Recommended UseCorporate Business, Small Business · Corporate Business, Small Business, Home Use · Corporate Business
ChipsetIntel 845G
Processor
Processor TypeIntel Pentium 4 · Intel Celeron
Processor Speed2.53 GHz · 1.8 GHz · 2 GHz · 1.7 GHz · 2.4 GHz · 2.66 GHz · 2.8 GHz · 3.06 GHz · 2.26 GHz · 2.1 GHz
Processor ManufacturerIntel
Processor UpgradabilityUpgradable
Max Processors Qty.1
Installed Qty1
Motherboard
Bus Speed400 MHz · 533 MHz
Video Output InterfaceAGP · AGP 4x
Technical Features
Expansion SlotsPCI x 3 · AGP x4 x 1
Integrated Input/Output PortsSerial Port x 2 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · USB 2.0 x 6 · RJ45 Lan Port x 1
Expansion Bays2 x 5.25" Half-Height (External Access) · 1 x 3.5" Third-Height (Internal Access) · 2 x 3.5" Third-Height (External Access)
Security FeaturesBoot Sequence Control · U-Bolt Anchoring Feature · Slot For Cable Lock · Power-On Password · Administrator Password
Power ConfigurationsACPI/APM Power Management · Wake On LAN Header · Wakeup from Keyboard/Mouse
Memory
RAM TechnologyDDR SDRAM
Installed RAM256 MB · 512 MB · 128 MB
Installed Cache Memory512 KB · 128 KB
Max Supported RAM2 GB · 1 GB
Installed Video Memory64 MB · 32 MB
Supported RAM Speeds266 MHz
Number of Memory Slots2 x 184 Pin DIMMs
Hard Drive
Controller TypeEIDE · IDE
Hard Drive Capacity40 GB · 80 GB
Hard Drive InterfaceIDE · DMA/ATA-100 (Ultra)
Hard Drive Rotation Speed7,200 RPM
CD / DVD
Optical Drive TypeCD-ROM · CD-RW · DVD-ROM · CD-RW/DVD-ROM (Combo)
Optical Drive Read Speed16x (DVD) · 48x (CD) · 40x (CD) · 6x (DVD)
Optical Drive Write Speed40x (CD-R) · 48x (CD-R)
Optical Drive ReWrite Speed24x (CD-RW)
Other Drives
Floppy Drive3.5" 1.44 MB floppy
Audio / Video
Audio Output TypeSound Card · Headphones · Line Out
Max. Video Resolution1600 x 1200 · 2048 x 1536
Graphic ProcessorIntel Extreme Graphic
Audio InputMicrophone Jack · 1 x Line In
Video Out Ports15 Pin D-Sub VGA port x 1
Integrated AudioAC'97 Audio Codec
Networking
Data Link ProtocolEthernet · Fast Ethernet · Token Ring · Gigabit Ethernet
Networking TypeNetwork Adapter · Integrated 10/100 Network Card
Dimensions
Depth16 in.
Height5.5 in.
Width7.49 in.
Weight29.55 lb.
Warranty
Warranty3 Years
Supported Models
830131U, 830141U, 830151U, 830152U, 830153U, 830161U, 830181U, 8301E1U, 8301KDU, 830314G, 830321U, 830322U, 830322UJ, 830324U, 830326U, 830327U, 830331U, 830335U, 830335UJ, 830336U, 830341U, 830342U, 830343U, 830344U, 830352U, 830352UJ, 830353U, 830354U, 830354UJ, 830361U, 830362U, 830381U, 830382U, 8303D1U, 8303D3U, 8303E2U, 8303H5U, 8303HGU, 8303K12, 8303K62, 8303K72, 8303KPU, 8303M6U, 8303MSU, 8303NDU, 8303XX1, 830442U, 830521U, 830522U, 830525U, 830529U, 830531U, 830534U, 830537U, 830539U, 830541U more...
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
