20 Most Recent Kenmore HE2t 3.7 cu. ft. Front Load Washer Questions & Answers
htc sensor isnt working i would recon
perhaps the element isnt getting power
did it trip your circuit breaker
some times the htc fails
all you get is machine stop because the heater is not detected
if it spins rinses and empties in a timely manner
then all thats left is the heater system
Kenmore HE2t 3.7... | Answered on Jan 10, 2015
the door interlock is basicaly a heated switch
it locks then hold it locked
but there is a sensor to check its closed in the first place
i think the interlock sensor isnt right
replace the door interlock is the first step
http://www.ebay.co.uk/itm/WHIRLPOOL-SPORT-MAYTAG-EPICZ-KENMORE-HE2-Door-Lock-W10253483-46197023640-8540772-/141476775106?pt=LH_DefaultDomain_0&hash=item20f0ac44c2
here is one i found on ebay
its not cheep so shop around a bit now you know a few equivelant types .,.. and models
Kenmore HE2t 3.7... | Answered on Dec 09, 2014
You may have to unplug it for about 15 minutes and try again. I had a similar problem and this helped.
Kenmore HE2t 3.7... | Answered on Mar 19, 2014
This should take 30 minutes: Remove the panel that is located below the front door, there are 3 small screws located at the bottom that hold this... you will see the water pump, which has a access screw plug. Unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean out, then put everything back... this should fix the issue.
Before you re-fit the filter check to see that the blades of the pump further inside are turning well - no blocks. If the prob still persists you must examine pump.
http://www.youtube.com/watch?NR=1&v=4IBvHbQ_3pA&feature=endscreen
If helped click helped.
Kenmore HE2t 3.7... | Answered on Jan 09, 2014
if is leaking by the hose repair or chage and adjust very well the clip or replace because loose the pression.
God bless you
Kenmore HE2t 3.7... | Answered on Sep 30, 2012
IF you take the panel off the is below the door, there is a drain plug and you should take it out. YOU will get lots of WATER. Be ready. Clean this out and try again. The issue is most likely the water solenoid valve is bad or the board that controls it is bad. You can also find the tech sheet when you look for the drain. It has all the tests that you can run.
Kenmore HE2... | Answered on May 17, 2019
There are two control boards (parts 3 and 6) shown here: http://www.searspartsdirect.com/model-number/11047571601/0582/0153200.html . Make sure to look at the Control Panel diagram. Part 3 is http://www.searspartsdirect.com/part-number/8540490/0026/110.html?modelNumber=11047571601&categoryName=Residential%20Washers&brandName=KENMORE . Part 6 is http://www.searspartsdirect.com/part-number/W10022320/0026/110.html?modelNumber=11047571601&categoryName=Residential%20Washers&brandName=KENMORE . With these part numbers, you should be able to find them online. They will be listed as Whirlpool or Whirlpool OEM parts.
If you add a comment with the problem that led you to have a technician look at the washer, I will confirm which board is which. I suspect part 6 is the B board but I'm not certain of that.
I hope this helps.
Kenmore HE2... | Answered on Apr 20, 2017
Kenmore HE2t 3.7 cu. ft. Front Load Washer Logo
Popular Tags
32 questions posted
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
View Most Popular
HE2 Kenmore
  • HE2 Kenmore
Most Popular Question
leaking hose part no 1344559
  • Washing Machines
